    Printer resetting mid print
    365
    • cw7_undefined
      cw7_
      lately my printer is just resetting mid print. I'm driving a Duet Wifi with an E3D Chimera with the latest stable firmware. The reset is mostly happening after a while and never at the beginning. It's happening with Cura and Prusaslicer generated gcode files and with different STL's. I also tried a different SD card with no effect.
      Here's the M122 output directly after a reset:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-956GU-DJMSJ-6J9FJ-3SD6N-KTPZG
      Used output buffers: 3 of 24 (13 max)
      Static ram: 25680
      Dynamic ram: 93080 of which 0 recycled
      Exception stack ram used: 268
      Never used ram: 12044
      Tasks: NETWORK(ready,764) HEAT(blocked,1232) MAIN(running,3768) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:00:23 ago, cause: power up
      Last software reset at 2019-12-10 00:27, reason: User, spinning module GCodes, available RAM 11924 bytes (slot 0)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 38.6, current 39.8, max 40.1
      Supply voltage: min 24.4, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2019-12-10 01:47:47
      Cache data hit count 73739878
      Slowest loop: 2.08ms; fastest: 0.06ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 15.79ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is running
      WiFi firmware version 1.23
      WiFi MAC address 5c:cf:7f:76:64:03
      WiFi Vcc 3.33, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 25464
      WiFi IP address 192.168.175.48
      WiFi signal strength -48dBm, reconnections 0, sleep mode modem
      Let me know if you need any more information. Thanks in advance,
      Christian
        Can you include your config.g and a description of the printer hardware?
        cw7_undefined 1 Reply Last reply Reply Quote 0
        • cw7_undefined
          cw7_ @Phaedrux
          @Phaedrux said in Printer resetting mid print:
          Sure.
          Here's my config.g:
          ; generated by RepRapFirmware Configuration Tool v2.1.3 on Thu Dec 05 2019 12:55:57 GMT+0100 (Mitteleuropäische Normalzeit)
          G90                                             ; send absolute coordinates...
          M83                                             ; ...but relative extruder moves
          M550 P"CW7_MK II"                                 ; set printer name
          M552 S1                                         ; enable network
          M586 P0 S1                                      ; enable HTTP
          M586 P1 S0                                      ; disable FTP
          M586 P2 S0                                      ; disable Telnet
          M569 P0 S1                                      ; physical drive 0 goes forwards
          M569 P1 S0                                      ; physical drive 1 goes backwards
          M569 P2 S0                                      ; physical drive 2 goes backwards
          M569 P3 S0                                      ; physical drive 3 goes forwards
          M569 P4 S0                                      ; physical drive 4 goes backwards
          M584 X0 Y1 Z2 E3:4                              ; set drive mapping
          M350 X16 Y16 Z16 E16:16 I1                      ; configure microstepping with interpolation
          M92 X100.00 Y100.00 Z400.00 E470.60:474.63      ; Set steps per mm
          M566 X800.00 Y800.00 Z12.00 E100.00:100.00      ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E250.00:250.00      ; set accelerations (mm/s^2)
          M906 X700 Y700 Z700 E700:700 I30                ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                         ; Set idle timeout
          M208 X-31 Y-7 Z0 S1                             ; set axis minima
          M208 X220 Y220 Z220 S0                          ; set axis maxima
          M574 Z1 S0                                      ; set active low and disabled endstops
          M574 X1 Y1 S3                                   ; set endstops controlled by motor stall detection
          M558 P5 H5 F120 T6000                           ; set Z probe type to switch and the dive height + speeds
          G31 P500 X0 Y0 Z0                               ; set Z probe trigger value, offset and trigger height
          M557 X15:195 Y15:195 S20                        ; define mesh grid
          M307 H0 B0 S0.60                                ; disable bang-bang mode for the bed heater and set PWM limit
          M305 P0 T100000 B4138 R4700                     ; set thermistor + ADC parameters for heater 0
          M143 H0 S130                                    ; set temperature limit for heater 0 to 130C
          M301 H1 S0.60                                   ; set heater 1 PWM limit to 60%
          M305 P1 T100000 B4138 R4700                     ; set thermistor + ADC parameters for heater 1
          M143 H1 S285                                    ; set temperature limit for heater 1 to 285C
          M301 H2 S0.60                                   ; set heater 2 PWM limit to 60%
          M305 P2 T100000 B4138 R4700                     ; set thermistor + ADC parameters for heater 2
          M143 H2 S285                                    ; set temperature limit for heater 2 to 285C
          M106 P0 S0 I0 F250 H-1                          ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S0.5 I0 F250 H1:2 T45                    ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M563 P0 D0 H1                                   ; Define tool 0
          G10 P0 X0 Y0 Z0                                 ; Set tool 0 axis offsets
          G10 P0 R0 S0                                    ; Set initial tool 0 active and standby temperatures to 0C
          M563 P1 D1 H2                                   ; Define tool 1
          G10 P1 X20 Y0 Z0                                ; Set tool 1 axis offsets
          G10 P1 R0 S0                                    ; Set initial tool 1 active and standby temperatures to 0C
          ; Custom settings
          M501
          M915 Y H400					; stall config for Y
          M915 X H400					; stall config for X
          M671 X30:30:150:150 Y30:150:150:30 P0.5 	; Bed leveling Points (X0/Y0, X0/Y190, X175/Y190, X175/Y0)
          M581 X T2 C0 S0					; Configure trigger
          The printer itself is pretty much custom build. It origins from an Anet A8 but there are pretty much only the stepper motors and the z spindles left. It's running on 24V, powered by a Meanwell 320W power supply.
          The E3D Chimera is set up with 24V 40W heating cartridges and 100k NTC thermistors and the heated bed is an Anycubic Ultrabase.
          Let me know if I missed anything.
          Christian
            The only thing that occurs to me is that the MCU temps reported by the M122 and then seeing that the printer may be in an enclosure?
            Have you gone through this process to calibrate the MCU temp sensor?
            https://duet3d.dozuki.com/Wiki/Calibrating_the_CPU_temperature
            Is there any active cooling on the board?
            cw7_undefined 1 Reply Last reply Reply Quote 1
            • cw7_undefined
              cw7_ @Phaedrux
              There are actually two fans. You can barely see them on the picture. One going directly onto the board, and one exhaust fan above.
              Usually the temperature in the enclosure doesn't exceed 30°C, even with the heated bed set to 100°C. As far as I can tell the MCU temperature is at around 40°C when printing. The last two prints failed at around 45 minutes.
              I'll try to calibrate the MCU temperature sensor tomorrow and report back.
              Thanks for your help so far.
              Christian
                The reported last reset in the M122 is power up. Which I think would indicate a powerloss. Is the PSU also in the enclosure? Could it be failing?
                cw7_undefined 2 Replies Last reply Reply Quote 0
                • cw7_undefined
                  cw7_ @Phaedrux
                  Yeah, the PSU is mounted to the printer. It's a Meanwell RSP-320 with a fan so I'm not sure if that can fail.
                  • cw7_undefined
                    cw7_ @Phaedrux
                    @Phaedrux I just remembered I had some issues when I initially set up the Duet. It would restart if I set the PWM limit for the heaters too high. So my guess would be that something draws too much power and when the PSU gets a little warm it just cuts off. Do you think that'd be a possibility?
                    This is my heater configuration
                    Christian
                      What is the wattage of the heated bed? Are you sure it's a 24V heater?
                      The greatest draw would be during the warm up phase. Once it's at temp it doesn't take as much power to keep it warm, especially since you have it in an enclosure.
                      • cw7_undefined
                        cw7_ @Phaedrux
                        @Phaedrux it should draw 140-145 watts. Here's the data sheet:
                        Heat Bed Power: 140-145W
                        Heat bed Specification:
                        (1)Material: Aluminum base
                        (2)Voltage: 12V/24V
                        (3)Max Temperature: 120 Degree Celsius
                        (4)Dimensions: 220mm x 220mm
                        (5)Thickness: heat bed 1.5mm
                        (6)Resistance around 0.9ohm for 12V
                        (7)Resistance around 3.6ohm for 24V
                        (8)100 Degree Celsius supported for both 12V and 24V
