Duet 2 Wifi Antenna
  • Looking to move to the new version of the Duet2 Wifi with external antenna. Is there any details on the antenna that comes with the unit? In particular I am looking for the size of the thru hole for mounting as well as the antenna cable length. I didn't see it in the wiki yet.
    I have just measured one:
    Threaded bush diameter 6.2mm
    Max panel thickness 3.8mm (if you use the nut but leave off the 2 washers), or 5.2mm (if you don't use the nut but screw the bush into a 3D printed part)
    Cable length to Duet about 130mm
