    First layer level issues delta
    718
    • Lakemanundefined
      Lakeman
      After upgrading my Anycubic predator to a duet wifi with mag ball arms and smart effector I cannot get a decent first layer.
      This is the first time I am using the duet, the smart effector and duet wifi and mag ball arms are installed at once.
      Before the upgrade I had no issues getting a good first layer after some playing around with the baby steps. The main reason was that is was inconsistent and temperamental. Also some prints went wrong half way without reason by shifting along the X or Y axis. Because of the amount of use and time spent on those things wen it went wrong again I decided to upgrade.
      After some advice here on the forum I used the auto delta calibration to set the parameters in config.g
      After that did a mesh level compensation. After that started the print, but the first layer is not consistent, at some points it is scraping the bed, and at other points the layer lets go of the bed.
      The mesh level compensation looks something like this:
      This same tilt is always there, also after the auto delta calibration.
      Also below the config.g file I am using at the moment.
      I hope the forum can help me resolve these issues, if you need any more information please let me know.
      ; generated by RepRapFirmware Configuration Tool v2.1.3 on Sat Dec 07 2019 21:21:10 GMT+0100 (Midden-Europese standaardtijd)
      M550 P"Predator" ; set printer name
      M665 R227.865 L440.5 B185 H418.866 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0.171 Y0.129 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X80.00 Y80.00 Z80.00 E400.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X2 Y2 Z2 S1 ; set active high endstops
      M558 P8 R0.5 A3 S0.02 H3 F200 T6000 ; set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
      M557 R185 S40 ; define mesh grid
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M106 P1 S1 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      • rodekundefined
        rodek
        Have you followed the instruction here https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
          droftarts administrators
          This is a good page for understanding why the bed shape is the way it is: http://boim.com/DeltaUtil/CalDoc/Calibration.html
          • garyd9undefined
            garyd9
            What mechanism is being used to level the bed? IR Sensor? Piezo? Smart Effector? BLTouch? Something else?
            Can you also post your bed.g file? That will show us which (and how many) points your probing, as well as the type of leveling you are doing.
            Take care
            Gary
            "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
            • Lakemanundefined
              Lakeman
              Thanks for the help so far. I did mix up the XYZ values of M665 and M666. So that is done correctly now (I think ;))
              M665 R227.9 L440.48 B185 H418.879 X0.217 Y0.125 Z0 ; Set delta radius, diagonal rod length, printable radius and homed height
              M666 X0.3 Y-0.08 Z0 ; put your endstop adjustments here, or let auto calibration find them
              This does does make the level a lot better when starting the mesh grid compensation
              However the root problem stays the same. The first layer is better with the mesh compensation not activated. But in both cases not as good as the standart predator.
              Here the bed.g:
              ; bed.g
              ; called to perform automatic delta calibration via G32
              ; Probe the bed at 6 peripheral and 6 halfway points, and perform 6-factor auto compensation
              ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
              G30 P0 X0.00 Y185.00 Z-99999 H0
              G30 P1 X118.92 Y141.72 Z-99999 H0
              G30 P2 X182.19 Y32.12 Z-99999 H0
              G30 P3 X160.21 Y-92.50 Z-99999 H0
              G30 P4 X63.27 Y-173.84 Z-99999 H0
              G30 P5 X-63.27 Y-173.84 Z-99999 H0
              G30 P6 X-160.21 Y-92.50 Z-99999 H0
              G30 P7 X-182.19 Y32.12 Z-99999 H0
              G30 P8 X-118.92 Y141.72 Z-99999 H0
              G30 P9 X0.00 Y92.50 Z-99999 H0
              G30 P10 X80.11 Y46.25 Z-99999 H0
              G30 P11 X80.11 Y-46.25 Z-99999 H0
              G30 P12 X0.00 Y-92.50 Z-99999 H0
              G30 P13 X-80.11 Y-46.25 Z-99999 H0
              G30 P14 X-80.11 Y46.25 Z-99999 H0
              G30 P15 X0 Y0 Z-99999 S6
              ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
              ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
              • Lakemanundefined
                Lakeman
                I am using a smart effector by the way.
                If I would run an auto delta calibration just before each print, can I save the results somehow? Now I just write them down and change the config.g. But then I have to restart and home again. And after each homing I have slightly different results.
                  jay_s_uk @Lakeman
                  @Lakeman you can type in M500 to record the results to config-override.g
                  Then make sure you have M501 at the end of config.g and the overridden values will be loaded on start up
                  • garyd9undefined
                    garyd9
                    You don't HAVE to use mesh compensation when printing (or at all.) I run it once in a while on my own machine just to look at the pretty picture (to see if there are any problems going on that I'm not aware of - such as too much backlash.)
                    In my opinion, mesh compensation on a delta printer is a work-around for an uneven bed, and would be better solved with a flat build surface.
                    You also really don't have to run auto-calibration for every print. If you run auto-calibration and save the values via M500 (and your config.g contains a M501 at the end), a simple G28 to home your printer will have everything ready to print (assuming you have decent endstops on the delta towers.)
                    My typical workflow is to only run an auto-calibration when I'm changing filament. While I have no filament loaded (and so nothing is oozing) I heat up the bed and nozzle, clean the nozzle, and run an auto-calibration a couple times until the values stabilize. I then save it via M500 and ONLY run G28 before a print (not G32.) This saves me the annoyance of bad auto-calibrations that occur from filament stuck to the nozzle or oozing out.
                    • Lakemanundefined
                      Lakeman
                      It does work without mesh compensation. Increased the thickness of the first layer a bit to smooth out any imperfections, and that seems to work alright. On the origional predator I only used to level the bed when it goes to far of again, and the probe has to be installed seperately, so I also do not zero the bed, only the endstops on top. This usually works fine for a week and up to a month sometimes.
                      I will try to use the duet without mesh and see how it goes. If anybody has an idea why the mesh does not work I am still interessted.
