    (Duet 2 wifi) wifi wont connect when endstops are connected
    399
    • naeemiundefined
      naeemi
      Foolishly while Vin was powered and the board wired i plugged in my USB to configure wifi connection issues and have shorted the 3.3V line. Such that when end-stops are connected the wifi will not work (no blue light or connection), nor will (while power is off smh) USB connect, luckily USB C can handle whatever power the board was sending to my PC and i was able to disconnect after it gave me a warning. When the board alone is connected to USB the connection is just fine and all lights are flashing appropriately.
      Obviously, I should not run my machine without the end-stops connected. It cant be that connecting to USB while in power damages the board to this degree. Is there something I can do?
      • Danalundefined
        Danal
        NC (Normally Closed) endstop switches should be wired to the "outer two" pins on a Duet 2 WIFi, labeled "Gnd" and "Stop".
        If instead they are wired to the adjacent pair "+3.3V" and "Gnd", and they are normally closed, they will drag down the 3.3V to the point the board will not respond to USB or WiFi.
        @naeemi said in (Duet 2 wifi) wifi wont connect when endstops are connected:
        That warning is also symptomatic of incorrectly wired endstops. The board is trying to draw too much power through the USB, and the computer shuts this off and issues a warning.
        naeemiundefined zshoeundefined 2 Replies Last reply Reply Quote 1
        • Danalundefined
          Danal
          Oh, and connecting USB while VIN is powered should be absolutely OK with very few exceptions.
          The one "gotcha" would be if the USB computer was at a significantly different ground potential than the power supply attached to VIN. Depending on a bunch of things about how that power supply is made, what PC and how its power works, etc, etc, this can, very rarely, damage something.
          In the real world, either everything tends to be plugged into the same (set of) mains outlets, or the computer is a Laptop.
          So, normally VIN and USB is just fine.
          Do you think you had an exception? That caused a problem?
          • Vetiundefined
            Veti
            see
            https://duet3d.dozuki.com/Wiki/USB_ground_loops
              droftarts administrators
              You don't NEED endstops to run a machine; you can move the axes by hand to a specific position (eg corner of the bed) and set the position with G92. Alternatively, you could use motor stall homing if you have a hard stop at the end of each axis, at least for X and Y; see https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing. And use a probe rather than an endstop for Z. This, of course, depends on your machine layout.
              • naeemiundefined
                naeemi @Danal
                @Danal Thank you, that worked!
                • zshoeundefined
                  zshoe @Danal
                  @Danal you said that this will drag down the board so it doesnt respond to usb or wifi, thats exactly what happened to me. is there a way to fix it or is my board screwed now? my endstops werent working so i plugged them into the 3v but now my diag light is on and nothing is responding even when i reset the board. so i unplugged my endstops but nothing is working still
                  • Danalundefined
                    Danal
                    @zshoe There is not much way to predict. Leaving them shorted long enough could damage the 3.3v regulator. With everything disconnected, plug in USB only, and see if the 3.3V led is on and bright.
                      Phaedrux Moderator @zshoe
                      @zshoe Also, please start a new thread.
