    Bes conpensation varies depending in z-height
    Duet Web Control
    435
    • wildblueundefined
      wildblue
      WTF?
      20.12.2019, 19:36:49 M114
      X:0.000 Y:289.997 Z:1.000 E:0.000 E0:0.0 E1:0.0 E2:0.0 E3:0.0 E4:0.0 E5:0.0 E6:0.0 E7:0.0 E8:0.0 Count 47052 -47052 1097 Machine 0.000 289.997 1.000 Bed comp -0.314
      20.12.2019, 19:36:36 G1Z1
      20.12.2019, 19:36:08 M114
      X:0.000 Y:289.997 Z:0.000 E:0.000 E0:0.0 E1:0.0 E2:0.0 E3:0.0 E4:0.0 E5:0.0 E6:0.0 E7:0.0 E8:0.0 Count 47052 -47052 -558 Machine 0.000 289.997 0.000 Bed comp -0.349
      20.12.2019, 19:36:01 G1Z0
      • SIamundefined
        SIam
        guide-for-posting-requests-for-help
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        • wildblueundefined
          wildblue
          Firmware package 2.05, duet3d wifi
          Sorry.
          • SIamundefined
            SIam
            what kind of printer what kind of z probe ....
            • wildblueundefined
              wildblue
              CoreXY, Switch-Like Probe (Type 5).
              • SIamundefined
                SIam
                has this printer worket bevor or is it a new printer which name have your z-probe ? run your printbed smoth ?
                  dc42 administrators @wildblue
                  Do you have bed compensation taper enabled?
                  • wildblueundefined
                    wildblue
                    The Printer has worked before. As i wanted to optimize the precision by calibrating my probes, i found this phenomenon.
                    All Probes are Industrial Style probes with very high precision and repeatability. But the probes do Not generate the Numbers shown. And IT does Not Matter If or how good/Bad the printer performs, when the Numbers shown don't Match Up.
                    I have done a simple bed Leveling and moved the system to a XY Position. Then i moved my z-axis Up/down and get different values for the Z-compensation. my probes are not involved at this time.
                    • wildblueundefined
                      wildblue
                      Bed compensation taper is enabled...
                      But... I am Not printing.
                      Did i Understand this Feature the wrong way? I thought this slowly tapers Off the applied compensation while printing, to get to an even Plane any time in the Future. Not when measuring or calibrating and Not printing.
                      zaptaundefined 1 Reply Last reply Reply Quote 0
                      • wildblueundefined
                        wildblue
                        I did several probes before and could Not explain the values of the bed compensation variing between 0.032 and 0.031. every measurement with a different result. Not consistent at all.
                        • zaptaundefined
                          zapta @wildblue
                          @wildblue said in Bes conpensation varies depending in z-height:
                          That's easy to verify. Turn off compensation taper and repeat your experiment.
