    Header for external hardware reset switch
    Hardware wishlist
    • fcwilt
      fcwilt last edited by
      I would like to see a two-pin header included that would allow installing a hardware reset switch so I could duplicate the function of the reset switch on the board.
      • T3P3Tony
        Hi Frederick
        Thank you for the request - may I ask how this would be used? Is it a concern that the firmware resets wont work?
        Duet Hardware Designer
        www.duet3d.com
        • fcwilt
          @T3P3Tony:
          Hi Frederick
          Well the board includes a hardware reset button - yes?
          The way I am mounting the boards that switch is difficult to access so it would seem reasonable (to me) to be able to have a way to install an external switch that would do the same as the switch on the board.
          Currently I did implement the firmware reset using the "trigger" feature but will that approach interrupt and reset the printer regardless of what it is busy doing?
          Thanks.
          • c310
            c310 last edited by
            i see this header request reasonable too
            • T3P3Tony
              I have made a note of this request and we will look at it when doing the next board revision.
              www.duet3d.com
