add ethernet moudle to wifi
i just wonder if you can add Ethernet module to the duet wifi or remove the wifi moudle and replace it with 3 party spi ethernet moudle
yes if you are very competent at soldering.
@poohzaza said in add ethernet moudle to wifi:
Yes it's possible to remove the WiFi module and install the Ethernet module in its place. We sell the Ethernet module separately, so do a few of our distributors.
If the problem is WiFi signal strength, it's also possible to replace the ESP12S module by ESP07S plus external antenna.
