    Duet 3 Heated Bed Faulting
    Beta Firmware
    764
    • blt3dpundefined
      blt3dp
      Hi, I'm super confused on this. Would like to upgrade it to 3.0RC1 but states compatible Duet Software Framework is 1.2. The most current I can upgrade to via apt is 1.1.0.5 (which the firmware readme says is the min you can work with). 1.2 was released 7 days ago, shouldn't it be up on the package server?
      Also about 3.0RC1, it doesn't look like the file is there on github for the SBC, is it supposed to be there or is it supposed to be upgraded via apt also?
      My 3D Printing YouTube Channel
      Better Living Through 3D Printing
      Follow me on Instagram and Twitter
      Instagram
      Twitter
      • A Former User?
        A Former User
        are you tracking the stable or unstable apt source?
        • Danalundefined
          Danal
          Given that 3.0RC1 is a beta release, the matching DSF will be on the unstable channel. Run:
          wget -q https://pkg.duet3d.com/duet3d.gpg
          wget -q https://pkg.duet3d.com/duet3d-unstable.list
          sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/
          sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list
          sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg
          sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list
          And then
          sudo apt-get update
          sudo apt-get upgrade duetsoftwareframework
          As of a few minutes ago, that installs 1.2.1.0
          And to your final question: Upgrade RRF3 firmware via the DWC system upload; upgrade DSF via apt-get, as above.
          More info about stable vs. unstable channel: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
          • blt3dpundefined
            blt3dp
            @Danal said in Duet 3 SBC software/firmware upgrades:
            Thanks, that did it.
            Instagram
            Twitter
            • blt3dpundefined
              blt3dp
              I'm also having an issue with a fault on my heated bed.
              It's giving me the message that the temp didn't rise as quickly as expected.
              I don't think it's picking up the thermistor correctly, usually it idles around 25C, and now it's about 30C
              I'm using the equivalent settings as I was using previously on my Duet 2 Ethernet and 2.04
              Here's my previous heater section,
              M307 H0 B0 S1.00                            ; Disable bang-bang mode for the bed heater and set PWM limit
              M305 P0 T100000 B3590 R4700                 ; Set thermistor + ADC parameters for heater 0
              M143 H0 S130                                ; Set temperature limit for heater 0 to 130C
              M301 H1 S0.70                               ; Set heater 1 PWM limit to 70%
              M305 P1 T100000 B4388 C7.060000e-8 R4700    ; Set thermistor + ADC parameters for heater 1
              M143 H1 S290                                ; Set temperature limit for heater 1 to 290C
              And here's my current heater section,
              M308 S0 P"temp0" Y"thermistor" T100000 B3590          ; configure sensor 0 as thermistor on pin temp0
              M950 H0 C"out0" T0                                    ; create bed heater output on out0 and map it to sensor 0
              M143 H0 S130                                          ; set temperature limit for heater 0 to 130C
              M307 H0 B0 S1.00                                      ; disable bang-bang mode for the bed heater and set PWM limit
              M140 H0                                               ; map heated bed to heater 0
              M308 S1 P"temp1" Y"thermistor" T100000 B4388 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
              M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
              M143 H1 S290                                          ; set temperature limit for heater 1 to 290C
              M307 H1 B0 S0.70
              Instagram
              Twitter
              • Danalundefined
                Danal
                @blt3dp said in Duet 3 SBC software/firmware upgrades:
                The missing R value in the new definition is the likely cause of the idle discrepancy. It MIGHT also explain the fault.
                blt3dpundefined 1 Reply Last reply Reply Quote 0
                • blt3dpundefined
                  blt3dp @Danal
                  @Danal
                  I do think it has something to do with, unfortunately if I throw R4700 in my m308 command the temp goes to 9.8C
                  Instagram
                  Twitter
                  • Dougal1957undefined
                    Dougal1957
                    Duet 3 AFAIK use a 2200 ohm sense resistor so change the R from 4700 to 2200 and you should be back on track.
                    • blt3dpundefined
                      blt3dp
                      Adding R2200 to my M208 command has taken care of the temperature reading, it’s on line with what I used to see.
                      But, it still faults. I don’t think it’s a wiring issue. I can connect my heated bed directly to mains wiring (it’s 120VAC @ 4A) and DWC shows the temperature rising at a normal rate.
                      I’ve bench tested the SSR just in case and it’s working fine.
                      It really does look like the Duet’s not controlling it like it used to in 2.04
                      Instagram
                      Twitter
                      • Danalundefined
                        Danal
                        Perhaps take a look at M570, and adjust the timing of a fault.
                          dc42 administrators @blt3dp
                          @blt3dp, the M307 H0 command you posted suggests that you haven't run heater tuning on the bed heater.
                          To get default bed heater parameters, make sure that the M141 H0 command to declare the bed heater comes before the M307 H0 command. Otherwise, when the firmware sees the M307 command with no A C or D parameter, it will assume default parameters for an extruder heater.
                          • blt3dpundefined
                            blt3dp
                            @dc42 Correct, I haven’t run tuning in the bed heater. I knew it was a thing for hotends but I’ve never done it for the bed on any of my machines. I guess cause all my past machines have set the bed to bang-bang. Didn’t seem necessary to tune the PID parameters if I wasn’t using that mode. Which brings the question:
                            Using a SSR to switch a mains powered bed, PID or Bang-Bang?
                            I also tried the M141 H0 and it didn’t seem to change anything, I’ll PID tune.
                            Edit: Sure M141 is right? Guide wiki says that’s for setting chamber temp.
                            Edit again: guessing you meant the M140, prob a typo? I’ll try that before the M307
                            Instagram
                            Twitter
                            • blt3dpundefined
                              blt3dp
                              M140 H0 before the M307 didn’t appear to change anything.
                              Instagram
                              Twitter
                                Phaedrux Moderator @blt3dp
                                @blt3dp said in Duet 3 Heated Bed Faulting:
                                PID is almost always going to be the way to go.
                                • blt3dpundefined
                                  blt3dp
                                  I’ll try a PID tune.
                                  Instagram
                                  Twitter
                                  • blt3dpundefined
                                    blt3dp
                                    PID tuning did fix it, I'm still receiving a notification stating the heater is over powered and would reach 260C if left on at full power. Everything related to my bed can handle well in excess of 140C so I have a thermal fuse in place that will trip at 130C and kill it. How might I adjust or supress the heater overpowered message?
                                    Instagram
                                    Twitter
                                    Vetiundefined 1 Reply Last reply Reply Quote 0
                                    • Vetiundefined
                                      Veti @blt3dp
                                      you can not. that is just a warning.
                                      • blt3dpundefined
                                        blt3dp @Veti
                                        @Veti said in Duet 3 Heated Bed Faulting:
                                        I thought that might be the case, no worries.
                                        Instagram
                                        Twitter
