    Driver 3 fried on first move
    • brandon444undefined
      brandon444
      I've been working on my new build and got my hemera extruder mounted and then wired. Driver current was set at 800 as I didn't change it from my initial config. 24v from PSU. Motor was wired correctly making sure with multimeter. I go to make my first test extrude move with no filament and the motor skips then I get a driver 3 short to ground and overheating, driver shut off error. I could smell smoke so I look at the board and felt the driver and burnt my finger on it. I immediately unplug from the wall, disconnect my motor from the duet and plug back in. Still the same errors and driver getting hot with nothing plugged into it. I checked all my wiring and everything was fine.
      Thanks for the help guys
      • Danalundefined
        Danal
        Use an ohmmeter to check the resistance between pairs on the hemera extruder stepper motor.
        brandon444undefined 1 Reply Last reply Reply Quote 0
          brandon444 @Danal
          @Danal I had checked that before I even plugged in to make sure wiring was correct. Now the driver gets errors and heats up with out anything plugged in
          • Danalundefined
            Danal
            Hmmm... not good. Muy no bueno.
            • elmoretundefined
              elmoret
              @dc42 @T3P3Tony - Approval to replace?
                dc42 administrators @elmoret
                @elmoret said in Driver 3 fried on first move:
                Yes, approved.
