    PAUSE.G & RESUME.G for IDEX printer (DUAL, DITTO & MIRROR)
    • Trideoundefined
      Trideo
      Hi everybody,
      Board: Duet WiFi 1.02 or later + DueX2
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.04 (2019-11-01b1)
      Duet WiFi Server Version: 1.23
      Our IDEX printer uses different Tool configuration according to printing mode, executed by Macros.
      When pausing a SD print, we want each tool to go to his dedicated park zone (Ex1 to X park zone and Ex2 to U park zone).
      We couldn't define suitable pause.g and resume.g codes that work well independently from the printing mode (mainly due to U axis inversion for Mirror mode).
      We want a unique pause.g & resume.g code for all configurations.
      IDEX (basic one):
      M563 P0 D0 H1 S"Ex 1"
      G10 P0 X0 Y0
      G10 P0 R0 S0
      M563 P1 D1 H2 X3 S"Ex 2"
      G10 P1 X0 Y10.75
      G10 P1 R0 S0
      DITTO:
      M563 P0 D0:1 H1:2 X0:3 S"Super Tool DITTO"
      G10 P0 X0 Y0 U-200 S0 R0
      M567 P0 E1:1
      MIRROR:
      M563 P0 D0:1 H1:2 X0:3 S"Super Tool MIRROR"
      G10 P0 X0 Y0 U0 S0 R0
      M579 U-1
      Pause.g:
      M83 ; relative extruder moves
      G1 E-1 F1200 ; retract 1mm of filament
      G91 ; relative positioning
      ;G1 Z5 F300 ; lift Z by 5mm
      G90 ; absolute positioning
      G1 X-222 U222 Y-162 F12000 ; Park X and U
      ;G1 Z-5 F6000 ; lift Z by 5mm
      M98 P"0:/macros/5- Control LED/LED Rojo"
      resume.g:
      ; resume.g
      ; called before a print from SD card is resumed
      G1 X-222 U222 Y-162 F12000 ; Go to park
      G1 E30 F300 ; extrude 20mm of filament
      G1 X-222 U222 Y-100 F12000 ; Unpark
      G1 R1 X0 Y0 F12000 ; go back to the last print move
      M98 P"0:/macros/5- Control LED/LED Azul"
      Thank for your help,
      Simon
        dc42 administrators @Trideo
        If you can wait a little longer for RepRapFirmware 3.01, then you will be able to use if-statements in pause.g to execute different Gcode depending on which tool is selected.
        Trideoundefined 1 Reply Last reply Reply Quote 1
        • Trideoundefined
          Trideo @dc42
          @dc42 Thanks for your quick answer! It will be a revolution to be able to do that !!!!
          • Trideoundefined
            Trideo
            Hi There,
            We are currently running reprap Firmware V3.2, can we speak about this topic as meta command example?
            It will be a useful for us! There is a C, C++ programmer in our team who can't wait to start playing with it!!
            Best regards,
            Simon
