    Panel Due with RRF 3.0 issue
    PanelDue
    8
    22
    1.3k
    • Damienundefined
      Damien
      I know this is an old post but I am having similar problems with Paneldue 7i. The panel was working fine, even after I updated my Duet 2 Maestro board to 3.1.1. I decided to update the firmware in the paneldue and now its stuck on "connecting" and none of the buttons work.(i.e. Nothing happens).
      Any suggestions?
      • A Former User?
        A Former User @Damien
        @Damien said in Panel Due with RRF 3.0 issue:
        Any suggestions?
        read the https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md#reprapfirmware-310 before upgrading.
        All PanelDue users: the PanelDue connector (or IO_0 on Duet 3) is no longer dedicated to PanelDue, therefore if you connect a PanelDue to this port you must use the following command in config.g to enable it: M575 P1 S1 B57600. You can use baud rates other than 57600, however the IAP files all assume 57600 baud; therefore if you use another baud rate then PanelDue will not display firmware update progress.
