    Mini IR Probe configure issue
    • schoenbekooievaarundefined
      schoenbekooievaar
      I am having difficulties installing the Mini IR Probe with the Duet Maestro mainboard.
      When powered on the LED Blinks Twice & not 4 times.
      This means the device is not in analoge mode.
      When I put an object near the sensor the LED indicator goes on.
      Inside the Web Control I alway have a reading of 1000 (also when sensor is not connected)
      In config.g i have the following parameters set up:
      M574 X1 Y2 S1 ; Set active high end stops & Y endstop is at high(max) position.
      M558 P1 H5 F200 T9000 I0 R0.5 ; Set Z probe type mini ir sensor
      G31 P500 X-2 Y-16.4 Z1.043 ; Set Z probe trigger value, offset and trigger height
      M557 X30:270 Y30:270 S80 ; Define mesh grid
      How can I solve this problem?
      Are there things that i can measure / test to find the reason the sensor starts in digital mode instead of analogue mode?
      When I measure the voltage output of Z_probe In on the mainboard I get ~3V.
      Is this normal? I immediately get this reading when powered from USB. (did not check with PS ON)
        schoenbekooievaar
        In regard to my previous post:
        I did an extra test & disconnected the blue wire (signal In / Out)
        With only Vcc & GND connected the mini IR Probe LED blinks 4 times.
        My conclusion from this test is that the board does not correctly initialise the Probe.
        Is this a correct conclusion?
        Could this be because of the enstop configuration ("M574")?
        I have a Duet Maestro mainboard with the latest firmware: 3.0RC1 (2019-12-16b8)
        Ref: https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_Set_endstop_configuration
        M574 - RepRapFirmware 3 Parameters
        Xnnn Position of X endstop: 0 = none, 1 = low end, 2 = high end.
        Ynnn Position of Y endstop: 0 = none, 1 = low end, 2 = high end.
        Znnn Position of Z endstop: 0 = none, 1 = low end, 2 = high end.
        P"pin_name" Defines the pin name(s) that the endstop(s) for the specified axis are connected to. Needed when S=1.
        Snnn 1 = switch-type (eg microswitch) endstop input, 2 = Z probe (when used to home an axis other than Z), 3 = single motor load detection, 4 = multiple motor load detection (see Notes).
        ==> What to do if you want to use a Z probe for the Z-Axis
        Example:
        M574 Z1 S1 P"zstop" ; Z min active high endstop switch
        ==> no need to refer to the pin_name for the Z Probe_In?
        I would greatly appreciate if someone could help me with initialising the mini IR Probe in the config.g file for the Maestro board (firmware 3.0RC1)
        Vetiundefined 1 Reply Last reply Reply Quote 0
        • Vetiundefined
          Veti @schoenbekooievaar
          @schoenbekooievaar said in Mini IR Probe configure issue:
          that config line is not for rrf3 but for rrf2
          i suggest you generate a new config while selecting rrf3 in the configurator
          • T3P3Tonyundefined
            T3P3Tony administrators
            Did this work using RRF 2 previously?
            Its been ages since I used an IR probe but working through it:
            1. From what you said, you are setting this up as an Analog Z probe. starting with the assumption that you do not have another Z endstop connected then i think M574 should be:
            M574 Z1 S0
            1. You should be using M558 to setip the Z probe, something like:
            M558 P1 C"zprobe.in" H5 F120 T6000             ; set Z probe type to unmodulated and the dive height +
            speeds
            G31 P500 X2 Y10 Z2.5                            ; set Z probe trigger value, offset of 2 in X and 10 in Y and trigger height
            https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
            www.duet3d.com
            schoenbekooievaarundefined 1 Reply Last reply Reply Quote 1
            • Vetiundefined
              Veti
              it seems he is missing the entire io mapping. that is why i suggested to recreate the config.
              but if you want to adapt the config. you need to add io mapping for each endstop
              like
              the probe like tony said
              heater like
              and fans like
                schoenbekooievaar @T3P3Tony
                @T3P3Tony
                Worked perfectly, Thank you!!!
                  schoenbekooievaar @Veti
                  @Veti
                  Thank you for the tip!!! Will do this in the future to try and solve it myself.
                  I started from the BLV-Cube pre configured files.
                  For some reason the x & y endstop work without the suggested modification.
                  (will modify and test this anyway)
                  Also thank you for pointing out to the heater & fan setting.
                  Those are the next things I need to find out if it works as intended.
