    Some help with Bltoutch
    Third-party add-ons
    462
    • Chrabbanundefined
      Chrabban
      Hello, i just got a BlTouch and i have tried to look at the guied but i just cant get it to work.
      first thing, is the Bltoutch suposed to replace the Z-limit switch all togethere ? i dont know if i like it if its suposed to. these are my settings, if anyone have some time over just to see what is wrong i whold be realy happy 🙂 i have a DuetWifi2 that i got maby 4 month ago, and i am using the pins as shown in the guide ba6b3f23-ca4d-4bd9-982f-b774d519e469-bild.png
      my BlToutch in mounted on the hotend fan, might not be the best place but the only place i can right now.
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Thu Dec 26 2019 22:42:20 GMT+0100 (centraleuropeisk normaltid)
      M550 P"My Printer" ; set printer name
      M551 P"Chris87tian87!" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X4000.00 Y4000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E200.00 ; set accelerations (mm/s^2)
      M906 X900 Y900 Z900 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S20 ; Set idle timeout
      M208 X300 Y300 Z400 S0 ; set axis maxima
      M574 X1 Y1 Z1 S1 ; set active high endstops
      M307 H4 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T3900 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y55 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:290 Y55:300 S20 ; define mesh grid
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M143 H0 S90 ; set temperature limit for heater 0 to 90C
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T180 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1 T180 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @Chrabban
        @Chrabban said in Some help with Bltoutch:
        it is.
        however due to the change from switch to bltouch a lot of changes are required in the config and the homing files. and it looks like you missed some.
        i would suggest you create a new config in the configurator while inputing your old values.
        problems in your config
        picture looks like heater3 not 4
        B4138 is the default and wrong for your thermistors.
        you did not enable the z probe
        • Chrabbanundefined
          Chrabban
          This is what i got when i redid the config, and but in the right values for the bed and nozzle. and pin 8 is heater 3 or am i wrong ? 🙂
          ; generated by RepRapFirmware Configuration Tool v2.1.4 on Fri Dec 27 2019 22:36:43 GMT+0100 (centraleuropeisk normaltid)
          M569 P2 S0 ; physical drive 2 goes forwards
          M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M574 X1 Y1 S1 ; set active high endstops
          M574 Z1 S2 ; set endstops controlled by probe
          M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
          G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
          M557 X20:280 Y75:270 S20 ; define mesh grid
          M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0
          M143 H0 S100 ; set temperature limit for heater 0 to 100C
          M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
          M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0
          • Chrabbanundefined
            Chrabban
            hehe i missread your post a bit, about heater 3 and 4, that was one of the mistakes i made i can see now 🙂
            • Vetiundefined
              Veti @Chrabban
              @Chrabban
              is it working now?
              • Chrabbanundefined
                Chrabban
                sadly no, the prob is just sitting there red and inside, it wont drop, it started to go down and wanted to probe but that is not a good idea if the prob hasent droped so i had to turn it of so it dosent destroy my bed 😛
                  Please post your homez.g, homeall.g, deployprobe.g and retractprobe.g files.
                  • Chrabbanundefined
                    Chrabban
                    okey
                    ; homez.g
                    ; called to home the Z axis
                    G91 ; relative positioning
                    G1 H2 Z5 F3900 ; lift Z relative to current position
                    G90 ; absolute positioning
                    G1 H2 X20 Y75 F3900 ; go to first probe point
                    ;G91 ; relative positioning
                    ;G1 H2 Z5 F65 ; lift Z relative to current position
                    ;G90 ; absolute positioning
                    ; homeall.g
                    ; called to home all axes
                    G1 H1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                    G1 H2 X5 Y5 F3900 ; go back a few mm
                    G1 H1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass)
                    G1 H2 X20 Y75 F3900 ; go to first bed probe point and home Z
                    ;G1 S2 Z5 F65 ; lift Z relative to current position
                    ; deployprobe.g
                    ; called to deploy a physical Z probe
                    M280 P3 S10 ; deploy BLTouch
                    ; retractprobe.g
                    ; called to retract a physical Z probe
                    M280 P3 S90 ; retract BLTouch
                    • Vetiundefined
                      Veti
                      M280 P3 S10
                      so when you issue this command manually nothing happens?
                      there have been many reports with bad cabling on the bltouch side. check the crimp job of those wires.
                      Chrabbanundefined 1 Reply Last reply Reply Quote 0
                      • Chrabbanundefined
                        Chrabban @Veti
                        @Veti
                        Nothing happens when i try that command
                        Allt the cables is good, just tried them with my multimeter 😕
                          And you're certain you're using heater pin 3 as the servo control pin?
                          And you're certain you have the heater pin 3 unbound as a heater in config.g?
                          And you're certain you have no commands for heater pin 3 in config-override.g?
                            As you are not using a DueX expansion board, you need to add parameter I1 (that's letter-i digit-1) to the M280 commands in deployprobe.g and retractprobe.g. See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_Duet_2_WiFi_Ethernet_running_RepRapFirmware_Num_2.
                            • Chrabbanundefined
                              Chrabban
                              it is working now 😄 it was the I1 that was the last thing, tnx for all the help 😄
