    DUET 3 Fan Control
    • Hornetriderundefined
      Hornetrider
      Hi
      I am now building up my 2nd printer with Duet, but this time with DUET3.
      On Duet2WIFI I used the following to control the fan for board cooling.
      M106 P2 T40:50 H100:101:102 ; Set Fan speed to cool MCU
      With DUET3 I am a bit confused as the temp sensors have to be assigned.
      Reading thru dokumentation I could not find a hint on how to control the MCU Temp with a FAN for DUET3...but maybe it was just to late in the night 😉
      Will the M106 like above still work?
      Has somebody already made this with DUET3?
      Can't wait to finish this project 🙂
      Cheers
      • T3P3Tonyundefined
        T3P3Tony administrators @Hornetrider
        I have not setup a thermostatic fan using MCU temp on Duet 3 however this is how I believe it should work. First you need to setup the output pin you want to use as a fan:
        M950 F2 C"out7"
        Then setup a virtual temperature sensor for the MCU:
        M308 S3 Y"mcutemp" A"mcutemp"
        Then you stick them together using M106
        M106 P2 T45 H3.
        www.duet3d.com
        • Danalundefined
          Danal
          Working example for hot-end thermo fan:
          M308 S0 P"0.temp0" Y"thermistor" T100000 B3950 A"Bed"
          M950 F10 C"1.out6"
          M106 P10 S255 H1 T45    ; S = Speed of fan Px, Hxx = heater for thermo mode, T = temps for thermo mode.
          As @T3P3Tony pointed out, only defining the input (M308) to be the proc instead of a pin, only that will be different.
            Hornetrider
            Thanks T3P3Tony and Danal
            I will check it out.
