    Question regarding heat ranges...
    • genebundefined
      geneb
      A friend of mine can't post here because every time he tries, it aborts the post with "Post content was flagged as spam by Akismet.com"
      Here's his question:
      "I have a duet 2 wifi and works great but i am considering building a enclosure for my 3d printer. I am trying to find the safe operating temperature for the board before I begin designing the enclosure. it will come in handy when designing the enclosure."
      Thanks folks!
      g.
      • Vetiundefined
        Veti
        just a thought. you dont need to put the duet inside of the enclosure.
        • jens55undefined
          jens55
          As Veti says, don't put the Duet or the power supply into the enclosure.
          As far as allowable heat in the enclosure, I would not push it above 50C as you might exceed the safe temperature for the stepper motors (unless these are outside the enclosure).
          • genebundefined
            geneb
            The Duet is built into the printer (SeeMeCNC Artemis 300). the enclosure temperature is solely driven by the heat coming off of the heated bed.
            g.
