    Stuttering / Twitching extruduer
    • hbrownellundefined
      hbrownell
      I have just restarted the build process again, and everything seems to be running great sans the extruder. I get a "twitchy" back and forth in either the extrude or retract function. I checked the wiring and there were two leads that were reversed, but I'm still having issue even after having fixed that.
      [https://youtu.be/otrRUDcBz7g](link url)
      Any thoughts? Things to check?? Thank you!
      Here is my config.g
      ; generated by RepRapFirmware Configuration Tool v2 on Fri May 24 2019 20:44:40 GMT-0500 (Central Daylight Time)
      M550 P"3DPrinter" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Physical drive 0 goes Backwards
      M569 P1 S0 ; Physical drive 1 goes Backwards
      M569 P2 S1 ; Physical drive 2 goes forwards
      M569 P3 S1 ; Physical drive 3 goes forwards
      M92 X99.9 Y100.1 Z399.6183 E400.00 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z6000.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X1100.00 Y1100.00 Z1100.00 E1100.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X210 Y210 Z200 S0 ; Set axis maxima
      M574 X1 Y1 S1 ; Set active high endstops
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P500 X34.82 Y-8 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:195 Y15:195 S20 ; Define mesh grid
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      Vetiundefined 1 Reply Last reply Reply Quote 0
        @hbrownell said in Stuttering / Twitching extruduer:
        Are you sure you have the wires paired correctly?
        https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
        • Vetiundefined
          Veti @hbrownell
          your video shows an ungeared extruder. however 400 steps is normally for a 3:1 geared extruder.
