    Hostname.local
    Duet Web Control wishlist
    • AS-3D Druck
      AS-3D Druck last edited by
      Hi there,
      i got the Duet Wifi since today so sry if i didn't see this Feature already. 😉
      But i would be nice if it is possible to set a local network hostname like octoprint did it.
      The hostname could be YoureMachineName.local or set by the Customer. 🙂
      Best regards
      AS-3D Druck / Andre
      • T3P3Tony
        Have a look at the reference to mDNS in this: https://duet3d.com/wiki/Getting_connected_to_the_Duet_WiFi
        Duet Hardware Designer
        www.duet3d.com
        • AS-3D Druck
          Tryed to change the Name in the Config and entered the M550 MachineName in the command line but it shows only
          RepRap name: My Duet
          Best regards
          AS-3D Druck / Andre
            With firmware 1.18 and earlier, the MDNS name is the one you entered when you first connected to the Duet as an access point. With firmware 1.19, it is taken from the M550 name.
            • AS-3D Druck
              Ok, but i thougt 1.19 is currently a Alpha.
              I got installed:
              Firmwarename: RepRapFirmware for Duet WiFi
              Firmware Elektronik: Duet WiFi 1.0
              Firmware Version: 1.18.1 (2017-04-09)
              WiFi Server Version: 1.03 (ch fork)
              Web Interface Version: 1.15a
              Best regards
              AS-3D Druck / Andre
