bltouch v3.1 helpπ
HELLO
I hope someone can help. MeI have just setup my bltouch and have done everthing in this tutorial https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/#testandcalibrate my problem is that all works as in macros but the G30 S-1 command does nothing :/. I have to use the deploy macro and lower the z-axis instead but then once i set the G92 Z0 the pin stay's retracted with the bltouch red led flashing
then i have to use the alarm + drop pin macro to release the pin homez.g homeall.g config-override.g config.g thank you for any help
That tutorial is out of date. Use https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
there are a lot of errors in your config.
M574 Z0
this disable z endstops as well as probes
M307 H7 A-1 C-1 D-1
M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouchwhich on is it?
M558 P5 H3 F500 T4000 X0 Y0 Z1 ; Set Z probe type to switch and the dive height + speeds
P5 is not for bltouch
G31 P500 X0 Y0 Z1.150 ; Set Z probe trigger value, offset and trigger height
your offset is wrong
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M305 P1 X200double configuration and P1 is configured twice.
you homing scripts do not contain G30 commands.
i would strongly suggest that you use the configurator to create a new config
hello sorry for my delayed reply i have just used the configurator tool
I think it went well
i changed a few things config.g
G31 P500 X0 Y0 Z1.5
Change P500 to P25
You still need the X and Y offset.
@Phaedrux said in bltouch v3.1 help
P25
config.g getting there
M566 X1500 Y1500 Z1000 E200 ; set maximum instantaneous speed changes (mm/min)
M203 X2000 Y2000 Z375 E800 ; set maximum speeds (mm/min)
M201 X4000 Y4000 Z150 E800 ; set accelerations (mm/s^2)
M906 X900 Y900 Z900 E900 I30 ; set motor currents (mA) and motor idle factor in per centThe Z jerk value is a bit high perhaps. And the max speed and acceleration a bit low.
Try M556 Z300, M203 Z600, M201 Z300
For motor currents target 70% to 85% of the rated max for the motor.
M307 H7 A-1 C-1 D-1 ;disable heater 7 to free up for servo signal for BLTouch
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouchYou still have two heater pins unbound. If you're using Pin 3 for the BLtouch remove the H7, or vice versa.
M305 P1 X200You still have two different things configured for heater P1. A thermistor and PT100. Which are you using?
PT100
ok this is a confusing partim using pin 8 heater3 from here https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe and i'm using a PT100
In that case, delete
andM305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
config.g did i mention I'm 41 and shit a retaining most information.
thank you very much for you're patience
just so you know what your dealing with this is a iture of my "temp" setup
my Frankenstein mad up of abs
and also thats the way my bltouch stays after it hits home
@jobesynoob1234 said in bltouch v3.1 help
But does it deploy, retract, and trigger as expected?
yes
all macros work so i take it the red flashing light is normal:/ because when i move the z-axis up and home z again the probe stays retracted and moves up instead.
Not sure what this means exactly.
Is the BLTouch flashing red or just lit at all times?
@Phaedrux flashing
Flashing would indicate error state. At what point does it error?
@Phaedrux as soon as it probes the bed
But it stops movement as it should?
@Phaedrux i just tried to upload a video but files to big
and yup it stops but I can't use home z again until I click on the alarm release and drop pin macro
because it will just keep moving up on every press
You can add that command to the start of your homing files to make sure the probe is ready before homing.
Still doesn't explain why it's erroring. But if it works otherwise I'm not sure what else to say.
@Phaedrux yup thats why its driving me nuts π€―and being a noob don't help
tomorrow i will solder all bltouch wires to eliminate connectors
and see if that helps. Thank you so much for helping me on this thing
hopefully I will win
well that was a waste of time
soldered wires made no difference!
i also forgot about the error message after i used the G30 S-1 that says the (Z probe already triggered at start of probing move) its very confusing how all macros work and the only macro that seams to work different is the self test because they say it keeps going until you give it another command. But for me it stops its self after a bit -
post a picture of all your wiring
