bltouch v3.1 helpπ
In config.g you have
M280 P3 S10 I1 ; Alarm Release and Push-Pin down
But I don't think you want to deploy the pin at startup. I think S10 is just deploy, not alarm release. based on the Antclabs documentation: https://5020dafe-17d8-4c4c-bf3b-914a8fdd5140.filesusr.com/ugd/f5a1c8_d40d077cf5c24918bd25b6524f649f11.pdfInstead, try adding this to the end which will clear any error state and retract the pin. You can also add that to the start of the homez and homeall
; BLTOUCH PREP ; G4 S1 ; pause 1 second M280 P3 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed G4 S1 ; pause 1 second M402 ; Retract probe just in case it's still down
Your homeall will become this:
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v2 on Mon May 13 2019 10:59:27 GMT+0100 (British Summer Time) G91 ; relative positioning G1 Z5 F6000 S2 ; lift Z relative to current position G1 S1 X-290 Y-290 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 X5 Y5 F6000 ; go back a few mm G1 S1 X-290 Y-290 F360 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X150 Y150 ; move probe to bed center. Change as needed. G30 ; use the probe G1 X0 Y0 ; return to home position
And the same basically for homez, since you need to move X and Y to position the probe, you need X and Y homed first. So homez becomes redundant. Just use homeall. You can use homez for some other specific homing situation later if you wish.
Yes, except that you want the BLTouch prep stuff to happen FIRST before anything else to ensure the pin is up and any error cleared.
@Phaedrux right i have now cut/pasted it to the top on all 3
time to test it
Can you also manually test the deploy and retract probe files by sending M401 and M402? They should deploy and retract the pin.
Post your deployprobe.g and retractprobe.g files if they don't work.
@Phaedrux things are getting a bit exciting now
i hit home all it then homes x then y the moved to center and probed then the second time then ended like this
was it supposed to do it slooooow
Which part is slow?
It looks like it worked?
@Phaedrux all of the moving part
like a slug
If you send the command to do the self-test does it run continuously until you interrupt it? or does it still fail with a flashing error?
How bout this for homeall then. Change these lines to add a feed rate and the G30 will first do a fast probe and then slower ones.
G1 X150 Y150 F6000 ; move probe to bed center. Change as needed. M558 F600 A1 ; Dive fast once G30 ; probe Z M558 F120 A10 ; Slow second dive with more accuracy G30 ; probe z again G1 X0 Y0 F6000 ; return to home position
ooops forgot to say self test runs then stops after about 10
retract/deploy then stays solid red
Yes that looks right
@jobesynoob1234 said in bltouch v3.1 help
Looking at the BLTouch 3.1 manual it seems like self test is limited to 10 times now. So that's as expected.
@Phaedrux well it worked faster probed center 3 times this time before going home
so does this now mean i can sort my z offsets and G30 S1 should work
Yes I think you're set now.
this all probably could have bean easier if i could have uploaded videos
I am soooo greatfull for all your help you have no idea how much stress you have wiped out
my fingers are crossed still
thank you so much
Glad it's working out now. I should have taken a closer look at your homing files sooner. That was definitely part of the confusion.
