web interface partially stuck after button press
hi, after upgrading to 2.05Rc1, and web control 1.04, I've found that the web interface controls no longer responds after I click them once. That is, if I home by pressing the home all button, the button will be stuck in the rotating icon and never allows me to home again, until I press F5 to refresh the webpage. I suspected it was my homeall.g. I removed the suspicious tool changing line but the problem remains. As a result, everytime I put in a gcode or home, I need to press F5 to reset the webpage.
I've attached my homeall.g, config.g here in the post.config (1).g homeall.g
Not captured in the screenshot but I've also noticed that the extrude and retract buttons seem to be permanently greyed out under some conditions. Even refresh won't do it. This is when HE temp is okay for extrusion.
This also happens when sending G codes. sometimes, once a command is sent and executed, I can't send the next one in because the input field seems to be stuck in a 'processing' state, even though the machine status is 'idle'. I've attached a screenshot to show what I mean.
I've searched the forum and didn't find any post matching this problem. Any ideas?
Upgrade to the full 2.05 as there was a bug in 2.05 RC1 stopping it work with DWC 2.0.4
@jay_s_uk said in web interface partially stuck after button press:
hi thanks, I upgraded just now and the Home All button works, but Retract and Extrude buttons are still greyed out, I supposed there' something else going on? Extrude and retract macros work fine. Printing is otherwise fine, too.
