    Please Help with Sensorless homing of Z axis
    • Fickert
      Fickert last edited by Fickert
      So rather excited but was short on sleep last night.
      Have my new CoreXY build up and moving great. I got stall homing setup for X and Y with huge thanks to the people posting their homing scripts up. My issues are coming from the Z axis homing with stall homing.
      I have the homing engaged, but the bed does not stop at all when I apply pressure to the bed. Even when the motor starts skipping steps.
      Is Fxxx speed to slow? Or am I missing something else? I also cannot go any lower on my Z-axis current which is shown below. Is this the issue?
      Thanks!
      Config.g
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Thu Jan 02 2020 22:58:29 GMT-0500 (Eastern Standard Time)
      M550 P"Fickert's CoreXY"                           ; set printer name
      M667 S1                                            ; select CoreXY mode
      M569 P0 S1                                         ; physical drive 0 goes forwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M350 X256 Y256 Z256 E128 I0                        ; configure microstepping without interpolation
      M92 X800.00 Y800.00 Z12000.00 E420.00                 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X600 Y600 Z750 E800 I30                    ; set motor currents (mA) and motor idle factor in per cent
      M208 X390 Y390 Z420 S0                             ; set axis maxima
      M574 X1 Y1 Z1 S3                                   ; set endstops controlled by motor stall detection
      M558 P10 H5 F4000 T6000 S3 R0                              ; Stall Detection Z probe but set dive height, probe speed and travel speed
      M557 X15:390 Y15:390 S20                           ; define mesh grid
      M305 P0 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H-1                             ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45                          ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      Homeall.g
      [[language]]
      ; homeall.g
      ; called to home all axes
      M400			; make sure everything has stopped before we make changes
      M913 X50 Y50 Z63	; drop motor currents to 50%
      M915 X Y S3 R0 		; set sensitivity to +3 unfiltered
      G91			; use relative positioning
      G1 S1 X-400  F4000	; move X all the way left and stop at end
      G1 X16			; move to edge of glass
      G92 X0			; set X0 at edge of glass
      G1 S1 Y-400  F4000	; move Y all the way left and stop at end
      G1 Y42			; move to edge of glass
      G92 Y0			; set Y0 at edge of glass
      G1 X152 Y210		; go to back center of bed for measurement			; probe bed to set z0
      G30 Z			; probe bed
      G29 S1			; load heightmap
      G90			; back to absolute positioning
      M400			; make sure everything has stopped before we reset the motor currents
      M913 X100 Y100 Z100 	; motor currents back to 100%
      M574 X1 S0 		; redefine active low and unused microswitches
      M574 Y1 S1 		; redefine active low and unused microswitches
        Z axis stall detection is very tricky to implement, and even if you get it reliable when the machine is cold, the results will start to very when the motors warm up.
        How is your Z axis implemented mechanically? Is it a single motor? Is there any gearing between the motor and lead screw? Etc.
        As an aside, you microstepping is likely to cause you issues. X256 native microstepping on all axis is not recommended.
        The Duet2 2660 drivers have the option of using x16 microstepping for the step generator, and letting the driver interpolate that up to x256 for the motors without the added overhead on the CPU. It's a much prefered option because it gives the best of both worlds.
        Try M350 X16 Y16 Z16 E16 I1 and reset your steps per mm accordingly.
        If you then wish to experiment with higher microstepping letters you can simply send a new M350 command AFTER the existing M350 and M92 commands and the firmware will automatically recalculate the steps per mm values for you as long as they are set first for x16 microstepping.
        Example:
        M92 X80 Y80 Z1600 E89
        M350 E128
          Here's what I had from back when I experimented with Stall guard on the Z axis. It worked, but as I said the behaviour would change with motor temp. Z axis was a single 1.8 degree motor, 1:1 ratio with 1mm lead/pitch single start lead screw.
          Might have worked better with active cooling on the Z motor to reduce the temp issue. and using a 0.9 degree motor might have helped as well.
          ; 2_ZStallProbe.g
          ; Uses the Z axis StallGuard detection as a Z-Probe
          M291 P"Are you sure you want to proceed?" R"StallGuard Z-Probe" S3
          M280 P3 S160 I1 	; Alarm Release and Push-Pin UP, inverted signal
          G28
          G90                			; absolute positioning
          G1  X150 Y150 Z3 F4000 			; Always probe on the same spot
          M558 P9 Z0			; Disable BLTouch
          M558 P10 X0 Y0 Z1 H3 F200 T6000	A10 R0.1 S0.005    	; Enable Stall Z probe
          G31 X0 Y0 Z0 P200           		; Set Z probe trigger value, offset and trigger offset (overshoot due to springs)
          M574 Z1 S3         	    		; set Z-min to use motor StallGuard
          M913 Z40   		      		; reduce motor current to 20%
          M201 Z20				; Reduce acceleration mm/s2
          M915 Z S4 F0 R0			; Set StallGuard sensitivity for endstop homing
          M291 P"StallGuard Z-Probe Settings Loaded. Proceed with Probe?" R"Yes or No?" S3
          M400
          G30 S-1					; Find the bed Z=0 reference
          G1 Z3
          G30 S-1 				; do a couple of repeatability tests
          G1 Z3
          G30 S-1
          G1 Z3
          G30 S-1
          G1 Z3
          G30 S-1
          G1 Z3
          G1 Z3
          G1 Z3
          G30 S-1
          G1 Z3
          G30 S-1
          G1 Z3
          G30 S-1
          G1 Z3
          M400
          M291 P"Probing complete. Restoring settings." S3
          M913 Z100   		      				; restore current to 100%
          M201 Z300 						; Restore acceleration
          M915 Z S63 F1 R0					; Set StallGuard sensitivity for normal movement
          M574 Z1 S2						; Use zprobe and home to Z Min.
          M558 P9 X0 Y0 Z1 H3 F100 T6000 A10 R0.5	S0.005		; P9 for BLTouch, dive height 3mm, probe at 100mm/s, travel 6000mm/s, up to 10 probes, pause 0.5s
          G31 X-41.8 Y32.2 Z2.3 P25				; probe offset from nozzle, p is trigger value, set low for bltouch, set Z=0 for testing
