    PWM Output 4-20mA
    • andornotundefined
      andornot
      Is there any pwm outputs 4-20mA that i can use to control a phase angle controller to control IR strip lamps on the delta printer i am modifying ? The temperature control will be via a thermocouple.
      SpatialOne custom delta printer, upgrading to print PEEK, PEKK & Ultem
        You will need a PWM to 4-20mA converter for that. We designed and prototyped one for an OEM some time ago. I'll check whether we are allowed to publish the design.
        andornotundefined 1 Reply Last reply Reply Quote 0
        • andornotundefined
          andornot @dc42
          @dc42 Thanks, if it cannot be published, is there anyway around it i have a phase angle controller from RS 232-9353
          • A Former User?
            A Former User
            this thins?
            https://docs.rs-online.com/0e21/0900766b8002e5be.pdf
            says it can be current and voltage controlled, so you might be able to use a 5v pwm output and just smooth it if need be.
            • andornotundefined
              andornot @A Former User
              @bearer How would i do this, i have limited experience in electronics?
              • A Former User?
                A Former User
                That is analogue electronics, or voodoo as its also called .. but I recon a RC filter set to a frequency well below the pwm frequency should work if the controller draw power doesn't draw power from the 4-20mA loop.
                Just ask google or youtube for a "RC low pass fileter" and see if you have any components that will work. For something like this it hardly matters if the cutoff is 10, 100 or 1000hz as you can set the pwm frequency on the duet to match whatever components you may have on hand.
                • andornotundefined
                  andornot
                  Spoken to supply of the Phase angle controller and 0 to 5V PWM input is capable. What pins can i use on the duet to give this output and how would it be coded?
