    RepRapFirmware 3.0 is released!
    Firmware installation
    33
    131
    12.4k
      dc42 administrators @matej1006
      @matej1006 said in RepRapFirmware 3.0 is released!:
      Hello @dc42
      why i get G28 error when i want to home my locking actuator?
      What is the error message?
      matej1006undefined 1 Reply Last reply Reply Quote 0
      • matej1006undefined
        matej1006 @dc42
        @dc42 G28 Failed to enable edstops
          dc42 administrators @appjaws
          @appjaws said in RepRapFirmware 3.0 is released!:
          I have made changes to the config file for RRF3 but the fans are not working properly, the extruder fan is on all the time, the system fan is not working and the part fan comes on if I move the sliders on part or system.
          If you run M98 P"config.g", do you get any error messages?
          Some problems I can see:
          • The M308 command to create a sensor should come before the M950 command that uses it (twice in your config.g)
          • Your M308 commands include T4700, which means you have 4.7K thermistors. Remove that parameter
          • Max sensor number is 63, so you can't use sensor numbers 100 and 101
          appjawsundefined 1 Reply Last reply Reply Quote 0
            matej1006
            @dc42 said in RepRapFirmware 3.0 is released!:
            M98 P"config.g"
            if i send M98 P"config.g" there is no error
              Sounds like a problem with M574 commands. Please post your config.g file.
              matej1006undefined 2 Replies Last reply Reply Quote 0
                matej1006 @dc42
                and why i can't see in extra temperature for water
                ; generated by RepRapFirmware Configuration Tool v2.0.4 on Sat Oct 12 2019 15:44:24 GMT+0200 (Srednjeevropski poletni čas)
                G90                                     ; send absolute coordinates...
                M83                                     ; ...but relative extruder moves
                M80					; force the PS_ON line to 0V/GND; causing a voltage over relay, thus enabling it.
                					; With the relay active, it close the circuit of the Live wire, taking over to supply the Power Supply.
                M550 P"Toolchange printer"              ; set printer name
                M667 S1                                 ; select CoreXY mode
                M552 S0
                M552 S1                                 ; enable network
                M586 P0 S1                              ; enable HTTP
                M586 P1 S0                              ; disable FTP
                M586 P2 S0                              ; disable Telnet
                ; Debugging
                M111 S0                                 ; Debug off
                M929 P"eventlog.txt" S1                 ; Start logging to file eventlog.txt
                ;X and Y motors
                M569 P5 S0                              ; Drive 5 direction | Y Stepper
                M569 P6 S0				; Drive 6 direction | Y Stepper
                ;Z motors
                M569 P7 S0                              ; Drive 7 direction | Front Right Z
                M569 P8 S0                              ; Drive 8 direction | Back Z
                M569 P9 S0                              ; Drive 9 direction | Front Left Z
                ;Extruders
                M569 P1 S0                              ; Drive 1 direction | Extruder0
                M569 P2 S0                              ; Drive 2 direction | Extruder1
                M569 P3 S0                              ; Drive 3 direction | Extruder2
                M569 P4 S0                              ; Drive 4 direction | Extruder3
                ; Toolchanger actuator
                M569 P0 S1					; Drive 0 direction | Toolchanger Actuator
                M584 X6 Y5 Z9:8:7 U0 E1:2:3:4                   ; set drive mapping
                M671 X-28:172:458 Y146:402:146 S15 		; leadscrews at front left, rear middle and front right
                M350 X16 Y16 Z16 E16 U4 I1                 	; configure microstepping with interpolation
                M92  X80.00 Y80.00 Z400.00 E420.00 U20   	; set steps per mm
                M566 X900.00 Y900.00 Z12.00 E120.00 U750    	; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z1500.00 E1200.00 U10000 ; set maximum speeds (mm/min)
                M201 X800 Y800 Z20 E1000 U1500          	; set accelerations (mm/s^2)
                M906 X900 Y900 Z900 E800 U1000 I60            	; set motor currents (mA) and motor idle factor in per cent
                M208 X0 Y0 Z0 S1                        	; set axis minima
                M208 X420 Y380 Z480 S0                  	; set axis maxima
                M574 U1 S1                           		; Set homing switch configuration for toolchange lock. Both switches should be wired NC and in series.
                M574 X1 Y1 S1                           	; set active low and disabled endstops
                M574 Z1 S2 					; Set endstops controlled by probe
                M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T3000   ; Set Z probe type to modulated and the dive height + speeds
                G31 P467 X0 Y40 Z1.0 				; Set Z probe trigger value, offset and trigger height
                ; Bed Heater
                M308 S0 P"bedtemp" Y"thermistor" T100000 B4138                  			; configure sensor 0 as thermistor on pin bedtemp
                M950 H0 C"bedheat" T0        ; create bed heater output on bedheat and map it to sensor 0
                M143 H0 S120        ; set temperature limit for heater 0 to 120C
                M307 H0 B0 S1.00        ; disable bang-bang mode for the nozzle heater and set PWM limit
                ; Tool1 Heater
                ;M308 S1 P"spi.cs1" Y"rtd-max31865"                                                     ; configure sensor 1 as thermocouple via CS pin spi.cs1
                M308 S1 P"duex.e2temp" Y"thermistor" T100000 B4138                                      ; configure sensor 1 as thermistor on pin duex.e2temp
                M950 H1 C"duex.e2heat" T1                                                               ; create nozzle heater output on duex.e2heat and map it to sensor 1
                M143 H1 S280        ; set temperature limit for heater 1 to 280C
                M307 H1 B0 S1.00        ; disable bang-bang mode for the nozzle heater and set PWM limit
                ; Tool2 Heater
                ;M308 S2 P"spi.cs2" Y"rtd-max31865"                                                     ; configure sensor 2 as thermocouple via CS pin spi.cs2
                M308 S2 P"duex.e3temp" Y"thermistor" T100000 B4138                                      ; configure sensor 2 as thermistor on pin duex.e3temp
                M950 H2 C"duex.e3heat" T2                                                               ; create nozzle heater output on duex.e3heat and map it to sensor 2
                M143 H2 S280        ; set temperature limit for heater 2 to 280C
                M307 H2 B0 S1.00        ; disable bang-bang mode for the nozzle heater and set PWM limit
                ; Tool3 Heater
                ;M308 S3 P"spi.cs3" Y"rtd-max31865"                                                     ; configure sensor 3 as thermocouple via CS pin spi.cs3
                M308 S3 P"duex.e4temp" Y"thermistor" T100000 B4138                                      ; configure sensor 3 as thermistor on pin duex.e4temp
                M950 H3 C"duex.e4heat" T3                                                               ; create nozzle heater output on duex.e4heat and map it to sensor 3
                M143 H3 S280        ; set temperature limit for heater 3 to 280C
                M307 H3 B0 S1.00        ; disable bang-bang mode for the nozzle heater and set PWM limit
                ; Tool4 Heater
                ;M308 S4 P"spi.cs4" Y"rtd-max31865"                                                     ; configure sensor 4 as thermocouple via CS pin spi.cs4
                M308 S4 P"duex.e5temp" Y"thermistor" T100000 B4138                                      ; configure sensor 4 as thermistor on pin duex.e5temp
                M950 H4 C"duex.e5heat" T4                                                               ; create nozzle heater output on duex.e5heat and map it to sensor 4
                M143 H4 S280        ; set temperature limit for heater 4 to 280C
                M307 H4 B0 S1.00 									; disable bang-bang mode for the nozzle heater and set PWM limit
                ; Tool definitions
                M563 P0 S"TOOL1" D0 H1 F3  					; Define tool 1
                G10 P0 Z-3.75                   				; Set tool 1 offset from the bed
                G10 P0 R170 S190                				; Set tool 1 operating and standby temperatures(-273 = "off")
                ;M572 D0 S0.1				    			; Set pressure advance on Extruder Drive 0
                M563 P1 S"TOOL2" D1 H2 F4  					; Define tool 2
                G10 P1 Z-3.75         						; Set tool 2 offset from the bed with tool-0 as a reference.
                G10 P1 R170 S190                				; Set tool 2 operating and standby temperatures(-273 = "off")
                ;M572 D1 S0.1				    			; Set pressure advance on Extruder Drive 1,
                M563 P2 S"TOOL3" D2 H3 F5  					; Define tool 3
                G10 P2 Z-3.75                   				; Set tool 3 offset from the bed
                G10 P2 R170 S190         				; Set tool 3 operating and standby temperatures(-273 = "off")
                ;M572 D2 S0.1				    			; Set pressure advance on Extruder Drive 2
                M563 P3 S"TOOL 4" D3 H4 F6   					; Define tool 4
                G10 P0 Z-3.75                    				; Set tool 4 offset from the bed
                G10 P0 R170 S190		 				; Set tool 4 operating and standby temperatures(-273 = "off")
                ;M572 D3 S0.1				    			; Set pressure advance on Extruder Drive 3
                ;Water temp
                M308 S5 P"e1temp" Y"thermistor" T100000 B4138                   ;configure sensor 5 as thermistor on pin e1temp
                M950 F0 C"!Fan0+exp.pb6" Q25000 				; fan 0 is a 4-wire PWM fan so invert it, use high PWM frequency, tacho connected to PB6 on expansion connector
                M106 H0 S1 T25                                                  ; set fan 0 value. Thermostatic control is turned on
                T-1                                      			; select first tool
                  matej1006 @dc42
                  @dc42 i figurit out for homing u axe i stiil have problem with showing temp on graph and extra temp for water and MCU temp
                  • wilrikerundefined
                    wilriker @matej1006
                    @matej1006 If a sensor is not bound to a heater it needs to be given a name to show up in the UI. That's done with the A parameter for M308.
                    Manuel
                    My Tool Collection
                    • garyd9undefined
                      garyd9 @garyd9
                      @garyd9 said in RepRapFirmware 3.0 is released!:
                      Duet2 wifi h/w version 1.04
                      Printer is a normal delta (with 0.9 degree steppers)
                      Firmware is the first general release of RRF3
                      After starting my first print with RRF3 on a Duet2 WiFi, I'm seeing a LOT of hiccups using an identical configuration to what I used with RRF2 (where I only rarely saw a hiccup.)
                      A follow up on this: I wanted to test things in a controlled environment without a print going. So, with no heaters/fans/extrusion going on, I performed the following commands (while in absolute positioning mode):
                      G1 X0 Y-50 Z50
                      M122 // just to clear the hiccup count
                      M122 // just to make sure the hiccups were really at 0
                      G1 Y+50 F12000
                      M122
                      The second M122 showed 188 hiccups.
                      Is this normal for 0.9 degree steppers, 16 microsteps, and movements of only 100mm across the center of the bed at only 200mm/sec?
                      Same test, but with a F param of 10000 showed 20 hiccups. Slowing it down to 9000mm/min showed 2 hiccups.
                      (I didn't see these kinds of hiccups with RRF2 on the same config with moves this slow.)
                      @dc42? Is RRF3 ready for Duet2 boards controlling deltas?
                      "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
                        @garyd, I'll do some tests on maximum step rates in RRF3. I noticed that on my delta, I had to reduce the max speed to 200mm/sec when it was previously higher.
                        MrSteve920undefined 1 Reply Last reply Reply Quote 0
                        • Hornetriderundefined
                          Hornetrider
                          Updated done for DUET3 Standalone from 3.0RC2 to 3.0 without trouble.
                          Now going to do some prints to see if everything runs...
                          Great Job!
                          • appjawsundefined
                            appjaws @dc42
                            M98 P"config.g"
                            thanks dc42,
                            I am almost there now but I think you should know that the gcode documentation under M950 has a note "M950 needs to be before M106, M308 etc in config.g file"
                            appjaws - Core XYUV Duet Ethernet Duex5
                            firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                            Ormerod 1-converted to laser engraver, Duet wifi
                            OpenSCAD version 2024.03.18
                            Simplify3D 5.1.2
                            • appjawsundefined
                              appjaws
                              Nearly there.
                              My bed isn't heating up at all
                              RRF 2 old -- worked
                              M307 H0 A104.6 C986.0 D1.9 ;B0 ; Auto tune PID for bed heater
                              M305 P0 R4700 B3950 S"Bed Heater" ; bed thermistor R and B values
                              RRF 3 new -- not working
                              ; Thermistors and heaters
                              M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                              M950 H0 C"bed_heat" T0 ; create bed heater output on bedheat and map it to sensor 0
                              M143 H0 S70 ; set temperature limit for heater 0 to 70C
                              M307 H0 A104.6 C986.0 D1.9 B0 S1.00 ; Auto tune PID for bed heater
                              Thanks for any help
                              Simplify3D 5.1.2
                              Dougal1957undefined 1 Reply Last reply Reply Quote 1
                              • Dougal1957undefined
                                Dougal1957 @appjaws
                                @appjaws this is how my Heater section is configured on my delta with a Duet2 WiFi only difference is that I Use PT100's for my temp sensors so you will have to allow for that hop it helps.
                                M143 S300 ; Set maximum heater temperature to 300C
                                ;M305 P0 X201 ; Set thermistor + ADC parameters for heater 0 and remap it to channel 201
                                ;M305 P1 X200 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 200
                                M308 S0 P"spi.cs2" Y"rtd-max31865" F50
                                M308 S1 P"spi.cs1" Y"rtd-max31865" F50
                                M950 H1 C"e0_heat" T1
                                ;M307 H0 A199.0 C962.6 D5 B0
                                ;M307 H1 A409.7 C232.2 D4.5 B0
                                ;M307 H0 A161.6 C1109.8 D5.8 S1.00 V24.4 B0
                                M307 H0 A449.1 C783.3 D9.8 S1.00 V24.4 B0
                                M307 H1 A544.9 C280.1 D4.2 S1.00 V24.4 B0
                                Can't see anything wrong in yours mind may be worth just double checking that the Zero's are Zero and not O
                                Doug
                                  Hornetrider
                                  I found something odd, or it is just to late at night.
                                  This is my heater and fan definition:
                                  M308 S3 Y"mcu-temp" A"MCUTemp" ; configure sensor 3 as MCU Temperature
                                  M308 S4 Y"drivers" A"DriverTemp" ; configure sensor 4 as Dirver Temperature
                                  M950 F1 C"out8" Q500 ; create fan 0 on pin out7 and set its frequency
                                  M106 P1 S1 H1 T45 C"Tool Fan" ; set fan 0 value. Thermostatic control is turned on
                                  M950 F0 C"out7" Q500 ; create fan 1 on pin out8 and set its frequency
                                  M106 P0 S0 H-1 C"Part Fan" ; set fan 1 value. Thermostatic control is turned off
                                  M950 F2 C"!out4" ; create fan 2 on pin out4 and set its frequency
                                  M106 P2 H3:H4 T48:60 C"MCU FAN" ; set fan 2 value. Thermostatic control is turned on
                                  I have noticed that in this config the bedtemp drives the MCU fan....like the "drivers" is using the bed temp...and not the drivers temp.
                                  Can somebody please check?
                                  Am I missing something?
                                  Btw. how do I activate the tacho and get and on DWC?
                                  I have a DUET3 6HC with RRF3.0 in use
                                    dc42 administrators @Hornetrider
                                    To use a 4-wire fan including the tacho, create the fan like this:
                                    M950 F2 C"!out4+out4.tach" Q25000
                                    Check your config by running M98 P"config.g" to see if there are any error messages. You can also send M308 S2, M308 S3 and M106 P2 to check that the settings for the electronics cooling fan and associated sensors are correct.
                                      Hornetrider
                                      thx for reacting so fast.
                                      I will check on your input.
                                      Before my last post I run the following check...
                                      Considering that for basic setup:
                                      M950 F2 C"!out4" -> works
                                      M106 P2 H3:H4 T48:60 C"MCU FAN" -> shows strange behaviour as "drivers" is influenced by "bedtemp"
                                      I checked this by changing M106 to:
                                      M106 P2 H4 T48:60 C"MCU FAN"
                                      While MCUTemp stayed at ~40°C I run the bed heating to 50°C and at 48°C the fan started running....
                                      Then I made a recheck for only "mcutemp" like:
                                      M106 P2 H3 T38:60 C"MCU FAN"
                                      And everything worked as supposed: as MCUtemp came below 38°C the fan turned of.
                                      Any clues?
                                        What temperature does Driver Temp show in DWC while you heat the bed?
                                          Hornetrider
                                          0.0°C
                                            @Hornetrider said in RepRapFirmware 3.0 is released!:
                                            I've just spotted the problem. You are using:
                                            but it should be:
                                            M106 P2 H3:4 T48:60 C"MCU FAN"
                                            Sending M106 P2 would have revealed that it was monitoring sensors 0 and 3.
