Error when create filaments profils
  • Hello,
    Sorry for my english, in general I speak french...
    So, my problem appear when I try to create new filaments, the system didn't find "filaments" directory, I try to create directly by Duet_Web_Control interface, don't work.
    Then I remove the SD card from the Duet and put it in my PC, I create the "filaments" directory manualy, don't work...
    I delete and create a second time the "filaments" directory by Duet_Web_Control interface and restart the board.
    After that, when I try to create a new filamant, the system said that he can't create the directory "PLA" from my exemple below.
    What is wrong in my process ?
    Thanks for your help.
    Here is the error message :
  • Moderator
    Put the SD card in your PC and create a folder called 'filaments'.
  • @Phaedrux said in Error when create filaments profils:
    In sys directory or in root directory ?
    I found the 2 informations in the forum...
    Thanks
  • Moderator
    in the root of the SD card
  • OK, it's working when the "filament" folder is created in root, not in sys directory.
    Thanks
