    Printer stopt moving
    402
    • stienfromarden
      stienfromarden last edited by
      I have a weird and frustrating issue. Yesterday I used my printer, with no trouble at all.
      Today, I wanted to start a print and this happened:
      Printer homed, did a single probe and than it should start printing, BUT it doesn't move at all. The weird thing is that the requested speed is visible, and also the top speed, both the same. But there is just no movement.
      I tried to print files I printed yesterday but nothing seems to work. Manually moving the print head with G1 works, homing worked and extrusion is working..
      A solutions?
      Thanks A LOT in advance!
      Stijn
      • stienfromarden
        I found out just now, that the Z axis is clicking every 5 seconds. But nothing else is happening.
        • droftarts
          droftarts administrators last edited by
          Sounds like something has set the Z axis speed to very slow, so it's moving, but at a really slow feedrate, F1 (1mm a minute). If this is a gcode file, check it for errors.
          However, to diagnose further, please supply some more information. eg what Duet, firmware version, printer type, then post config.g and gcode that causes the error. See https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
          • stienfromarden
            That sounds like an option since the very slow clicking of the z axis.
            More information about the system
            WiFi Server Version: 1.22
            Web Interface Version: 1.22.6
            Printer type is a cartesian printer 900x900x1400mm
            Config G:
            config (3).g
            Also see attached gcode file, it's jus a tube I try to print as a test..
            tubev03.gcode
            thanks a lot!
            • Veti
              Veti last edited by Veti
              @stienfromarden said in Printer stopt moving:
              please update to at least 2.05.
              also
              M350 X16 Y16 U16 E16 I0 ; Configure microstepping without interpolation
              why are you not using interpolation?
              M574 X1 S0 Y2 S0 U2 S0 ; Set active low and disabled endstops
              this should be
              M574 X1 Y2 U2 S0 ; Set active low and disabled endstops
              M906 X2100.00 Y2100.00 U2100.00 Z800.00 E1400.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
              is you z axis motor that different? i would have excepted a similar motor as the others for such a huge machine.
              M569 P5 S1 R1 ; Physical drive 5 goes forwards (Z AXIS)
              why are you changing the polarity?
              stienfromarden 1 Reply Last reply Reply Quote 0
              • stienfromarden
                stienfromarden @Veti last edited by
                ok I'll do that first
                I use interpolation, but the 4 nema23 z axis motor are powered from 4 external stepper drivers (1/16)
                this should be
                Changed!
                That's due to the exernal stepper drivers.
                It's a while ago I wired everything so I don't know, but everything is moving the right way..
                • Veti
                  Veti last edited by
                  this says no interpolation for X Y U E.
                  M350 Z16 E16 I1 ; Configure microstepping with interpolation
                  This says interpolation for Z and E
                  • Veti
                    Veti last edited by
                    M204 S5000
                    G1 F540
                    G1 X411.326 Y408.547 E0.64352
                    did you set reprap instead of marlin in prusaslicer?
                    540 is 9mm/sec
                    • stienfromarden
                      ok changed that, but still no movement when printing...
                      Veti 1 Reply Last reply Reply Quote 0
                      • Veti
                        Veti @stienfromarden last edited by
                        @stienfromarden
                        and when you cancel the print you can issue move commands via the web ui?
                        • stienfromarden
                          @Veti
                          When I cancel the the print I cannot issue a move with the web ui. It also keeps clicking the Z axis when I cancel the print.
                          • stienfromarden
                            @Veti said in Printer stopt moving:
                            M204 S5000
                            G1 F540
                            540 is 9mm/sec
                            Jes I did. I try to change that!
                            • stienfromarden
                              ok, so when I choose marlin firmware in my PrusaSlic3r it moves very slow when homing before printing an then it stops, same problem as with reprap..
                              • Veti
                                what is the error on the console?
                                • stienfromarden
                                  This post is deleted!
                                  • stienfromarden
                                    No errors on the console weirdly, but I'm also not able to cancel the print, only pause it..
                                    • Veti
                                      Veti last edited by
                                      can you issue the commands M201 till M205 and post the outputs
                                      • stienfromarden
                                        I just updated the firmware, and now I have some other issues... trying to fix that first and than I will issue m201 till m205
                                        thanks so far, keep you updated 🙂
                                        • stienfromarden
                                          I get this error now
                                          • droftarts
                                            From your gcode file:
                                            M107
                                            M104 S200 ; set temperature
                                            G28 X0
                                            G28 Y0
                                            M561 ; Clear any bed transform that might be in place
                                            G30 ; Do a single probe
                                            M375 P"2020begin1.csv" ; Load my custom heightmap.
                                            G21 ; set units to millimeters
                                            G90 ; use absolute coordinates
                                            M83 ; use relative distances for extrusion
                                            ; Filament gcode
                                            G1 E-5.00000 F3600.00000
                                            G1 Z2.000 F18000.000
                                            G1 X409.730 Y410.094
                                            G1 Z0.500
                                            G1 E8.00000 F4800.00000
                                            M204 S5000
                                            G1 F540
                                            G1 X414.329 Y405.936 E1.15176
                                            You said it stops after the probe (G30). Does it do the filament retraction? The next move after that is a Z move at F18000 (300mm/s), too fast for you Z axis.
                                            stienfromarden Veti 2 Replies Last reply Reply Quote 0
                                            • Veti
                                              @stienfromarden
                                              its just a warning. but in the homing files change S1 to H1
                                              • stienfromarden
                                                ok, got it updated now and I looks like this;
                                                Firmware Version: 2.05 (2019-12-13b1)
                                                WiFi Server Version: 1.23
                                                • droftarts
                                                  Ignore those warnings for now. You can change them, in your home.g files, later, but the S is still supported in 2.05.
                                                  The "tube-marlin.gcode" file is different from the one you posted? Most likely, if the firmware is set to Marlin in PrusaSlicer, the slicer is adding the motor speed/acceleration/jerk codes. The main problem with that is that Marlin specifies these in mm/s, while RRF specifies them in mm/minute, so they are very low values for RRF.
                                                  • stienfromarden
                                                    stienfromarden @droftarts last edited by
                                                    @droftarts
                                                    Thanks, it does the retraction! So it's probably the 300mm/s Z travel, but where do I change that?
                                                    I tried the same gcode file and now zy moved for 20cm aprox.
                                                    • Veti
                                                      Veti @droftarts last edited by
                                                      @droftarts said in Printer stopt moving:
                                                      his config limits the max speed to Z400
