    Printer stopt moving
    1.5k
    • Vetiundefined
      Veti
      @stienfromarden said in Printer stopt moving:
      I use interpolation, but the 4 nema23 z axis motor are powered from 4 external stepper drivers (1/16)
      M350 X16 Y16 U16 E16 I0 ;
      this says no interpolation for X Y U E.
      M350 Z16 E16 I1 ; Configure microstepping with interpolation
      This says interpolation for Z and E
      • Vetiundefined
        Veti
        M204 S5000
        G1 F540
        G1 X411.326 Y408.547 E0.64352
        did you set reprap instead of marlin in prusaslicer?
        540 is 9mm/sec
        stienfromardenundefined 1 Reply Last reply Reply Quote 0
        • stienfromardenundefined
          stienfromarden
          ok changed that, but still no movement when printing...
          • Vetiundefined
            Veti @stienfromarden
            @stienfromarden
            and when you cancel the print you can issue move commands via the web ui?
              stienfromarden @Veti
              @Veti
              When I cancel the the print I cannot issue a move with the web ui. It also keeps clicking the Z axis when I cancel the print.
                @Veti said in Printer stopt moving:
                M204 S5000
                G1 F540
                540 is 9mm/sec
                Jes I did. I try to change that!
                  stienfromarden
                  ok, so when I choose marlin firmware in my PrusaSlic3r it moves very slow when homing before printing an then it stops, same problem as with reprap..
                  • Vetiundefined
                    what is the error on the console?
                      stienfromarden
                      This post is deleted!
                        stienfromarden
                        No errors on the console weirdly, but I'm also not able to cancel the print, only pause it..
                        • Vetiundefined
                          Veti
                          can you issue the commands M201 till M205 and post the outputs
                            stienfromarden
                            I just updated the firmware, and now I have some other issues... trying to fix that first and than I will issue m201 till m205
                            thanks so far, keep you updated 🙂
                              stienfromarden
                              I get this error now
                                droftarts administrators
                                From your gcode file:
                                M107
                                M104 S200 ; set temperature
                                G28 X0
                                G28 Y0
                                M561 ; Clear any bed transform that might be in place
                                G30 ; Do a single probe
                                M375 P"2020begin1.csv" ; Load my custom heightmap.
                                G21 ; set units to millimeters
                                G90 ; use absolute coordinates
                                M83 ; use relative distances for extrusion
                                ; Filament gcode
                                G1 E-5.00000 F3600.00000
                                G1 Z2.000 F18000.000
                                G1 X409.730 Y410.094
                                G1 Z0.500
                                G1 E8.00000 F4800.00000
                                M204 S5000
                                G1 F540
                                G1 X414.329 Y405.936 E1.15176
                                You said it stops after the probe (G30). Does it do the filament retraction? The next move after that is a Z move at F18000 (300mm/s), too fast for you Z axis.
                                stienfromardenundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                                • Vetiundefined
                                  @stienfromarden
                                  its just a warning. but in the homing files change S1 to H1
                                    stienfromarden
                                    ok, got it updated now and I looks like this;
                                    Firmware Version: 2.05 (2019-12-13b1)
                                    WiFi Server Version: 1.23
                                    Web Interface Version: 1.22.6
                                      Ignore those warnings for now. You can change them, in your home.g files, later, but the S is still supported in 2.05.
                                      The "tube-marlin.gcode" file is different from the one you posted? Most likely, if the firmware is set to Marlin in PrusaSlicer, the slicer is adding the motor speed/acceleration/jerk codes. The main problem with that is that Marlin specifies these in mm/s, while RRF specifies them in mm/minute, so they are very low values for RRF.
                                        stienfromarden @droftarts
                                        @droftarts
                                        Thanks, it does the retraction! So it's probably the 300mm/s Z travel, but where do I change that?
                                        I tried the same gcode file and now zy moved for 20cm aprox.
                                        • Vetiundefined
                                          Veti @droftarts
                                          @droftarts said in Printer stopt moving:
                                          his config limits the max speed to Z400
                                            Jes, I degraded back to 2.05 now, the warnings are gone, but first it didn't home when the warning turned on. That is fixed now!
