    From 16 to 256 Steps
    • AS-3D Druck
      AS-3D Druck last edited by
      Hi Guys,
      if i change my Standard 16 Steps to 256 Steps i need to calculate my Steps x 16 right?
      Best regards
      AS-3D Druck / Andre
        If you put the M350 command to change microstepping after you have already set the steps/mm using M92, then the steps/mm will be changed automatically to account for the changed microstepping. You can see this by sending M92 with no parameters to see what the new values are.
