    Flux issue?
    • RobMink
      RobMink last edited by RobMink
      Hello all! I was moving an axes and had the 4 lead screw gantry jam. This caused some of the steppers to jump steps. Now, I get a stepper drive shorted to ground on driver 2. I checked the wiring for shorts and found none. I am still getting the error when the motor is unplugged. Upon inspection, one of the driver MOSFETs and some other components where covered in a thick off white substance. Flux. Cleaning gently with a q tip and 91% isopropal I was able to get most of it off, but I think some is under the bottom most driver 2 mosfet IC on the HC6 0.6 V board. I have a photo attached of the after cleaning. You can see some corrosion on the electrolytic cap as well as some flux on the SMT (c215) cap, and the MOSFET (Q19).
      Thanks for taking the time to read this!
      • A Former User
        A Former User last edited by
        that flux is everywhere, under the chips too, it's normal and expected, it is no-clean flux so you do not need to clean it, it does not conduct electricity.. (even most of the flux solutions that are not "no-clean" do not have to be cleaned)
        "stepper shorted" usually means driver (or in case of duet 3 that comes with external fets, the fet) is dead. this is not supposed to happen on jam but if any of the motors had a lose wire that can blow the fets on the output (attaching/detaching motors while driver is enabled)
        • RobMink
          Hmm, Ok. What do you think caused the corrosion on the cap's Solder joint then?
          Thanks!
          • Catalin_RO
            Catalin_RO last edited by
            Looks more like a bad solder paste disposal in that area. Clearly the Q19 transistor soldering looks significantly different from the others. Maybe some dirt between the PCB and the mask having the final effect of too much deposited solder paste?
            RobMink 1 Reply Last reply Reply Quote 0
            • RobMink
              RobMink @Catalin_RO last edited by
              @Catalin_RO
              Thanks for looking! That might be it.
                Flux isn't normally white. My guess is that one of the mosfets failed and the white gunk came out of it. Do you have a photo of the board before you cleaned the white gunk off?
                • RobMink
                  unfortunately I do not.
                  Thanks
