    anyway to support this delta machine...
    402
    • netuserundefined
      netuser
      I make a delta robot , and want use it for printing ...
      but how to do it ... Is duet support it ?
      looks like this
      1. Is reprep support it ?
      2. If it support , what i should do
      3. If it don't support , what i should do if i want use it for printing...
      Thx !
      • Vetiundefined
        Veti
        see
        https://duet3d.dozuki.com/Wiki/Configuring_RepRapFirmware_for_a_Rotary_Delta
        • netuserundefined
          netuser
          Thx! looks Great !
          Is it available now ?
            dc42 administrators @netuser
            @live said in anyway to support this delta machine...:
            Thx! looks Great !
            Yes.
            Calibrating a rotary delta may be tricky. There is no auto calibration implemented yet.
            netuserundefined 1 Reply Last reply Reply Quote 0
            • netuserundefined
              netuser @dc42
              @dc42 OK, I'm being done
              In M669, What's Meaning of Rrr and Hxx:yy:xx
              i used two radiuss of Static platform and Moving platform past... it's hard to understand Rrr and Hxx...
              and any plan to support auto level..
              Thx!
              • Danalundefined
                Danal
                R is the
                • Radius of your UPPER (motor) pivot points, measured to the center of the pivot (joint, shaft, ball).
                • MINUS
                • The radius of the LOWEST (effector) pivot points, measured to the center of the pivot (joint, shaft, ball).
                Example: Upper = 175mm, lower = 53mm, R=123
                H is the VERTICAL distance from the UPPER (motor) pivots, measured to the center of the pivot, to the LOWEST (effector) pivots, measured to the center of the pivot, when Z is zero (nozzle just touching bed). In your setup, all three numbers will be identical (so you can just code one, if you wish)
                • netuserundefined
                  netuser
                  Thank you !
                  I'm sorry.... i just have some trouble...
                  it's my delta config:
                  R = 193.65
                  La = 287.5
                  Lb = 674
                  r = 102.46
                  And this is my M669
                  M669 K10 U287.5 L674 A-60:30 R91.19 H600
                  it can trige stop correctly, but it can't reach (100,*,0) or more far position , but it should reach it , and it not reach it's max angle
                  my stop is higher 30° then level..
                  I think level is 0°, is it correct ?
                  • Danalundefined
                    Danal
                    Meaning it homes correctly?
                    "Level" means the upper arms parallel to the ground.
                    What happens when, after homing, you G1 X0Y0Z0 F100? Does the nozzle go where you expect?
                    What about G1 X0 Y0 Z10? Does that lift the nozzle straight up 10mm?
                    netuserundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • netuserundefined
                      netuser @Danal
                      @Danal
                      yes , it can be home correct
                      also can up 10mm
                      but when i do G1 X100 Y0 Z10, it reports outside limits... but it should reach it ...
                      so.. anywhere config wrong? which config affect it ?
                        dc42 administrators @Danal
                        @Danal said in anyway to support this delta machine...:
                        More precisely, 0 degrees is when the joints at the inner and outer ends of the upper arms are at the same height. Quite often this won't be when the physical structure of the arm is parallel to the ground.
