Duet2 reboots at random time
  • Hello everyone,
    my Duet2 started to reboot at random times.
    I thought it would be the board, but i switched it and the problem remains.
    Basically i have some faulty peripheral.
    Connected to the board i have limit switches, stepper motors, thermistors and resistors...
    Well a faulty limit switch would give a false signal nothing more, a faulty thermistor would give false temperature values, a faulty resistor would not heat up ... so basically my question is, could a faulty stepper motor reset the board??
  • after the board reboots go to the g-Code console and enter M122 and post this results here
  • This is the report with 2.02 firmware:
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
    Used output buffers: 3 of 20 (18 max)
    Static ram: 25524
    Dynamic ram: 98640 of which 0 recycled
    Exception stack ram used: 512
    Never used ram: 6396
    Tasks: NETWORK(ready,544) HEAT(blocked,1232) MAIN(running,3780) IDLE(ready,200)
    Owned mutexes:
    Last reset 02:14:50 ago, cause: software
    Last software reset at 2020-01-06 16:36, reason: Watchdog timeout, spinning module GCodes, available RAM 6312 bytes (slot 1)
    Software reset code 0x4053 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f814 BFAR 0xe000ed38 SP 0x2000494c Task 0x4e49414d
    Stack: 004450eb 0042acdc 61000000 2000857c 200031d4 6f5523d2 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 0044bb0b 00000000 0044b913 00000008 0043943b 00000000 20009aa8 00000fff 6f5523d2 a5a5a5a5 0042acdd 20008570 20007a00
    Error status: 0
    Free file entries: 10
    MCU temperature: min 33.2, current 33.9, max 34.2
    Supply voltage: min 12.5, current 12.6, max 12.7, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: standstill, SG min/max 0/181
    Driver 1: standstill, SG min/max 0/172
    Driver 2: standstill, SG min/max 83/329
    Date/time: 2020-01-06 18:51:32
    Slowest loop: 4.35ms; fastest: 0.08ms
    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 238, MaxWait: 3420424ms, Underruns: 0, 0
    Scheduled moves: 10, completed moves: 10
    Bed compensation in use: none
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 202.49ms; fastest: 0.08ms
    HTTP sessions: 1 of 8
    - WiFi -
    Network state is running
    Failed messages: pending 0, notready 0, noresp 1
    WiFi firmware version 1.23
    WiFi MAC address dc:4f:22:6e:6f:97
    WiFi Vcc 3.42, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 25824
    WiFi IP address 100.100.100.102
    WiFi signal strength -60dBm, reconnections 0, sleep mode modem
    And this is the report with 2.05 firmware:
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
    Used output buffers: 1 of 24 (16 max)
    Static ram: 25712
    Dynamic ram: 93184 of which 372 recycled
    Exception stack ram used: 272
    Never used ram: 11532
    Tasks: NETWORK(ready,752) HEAT(blocked,1232) MAIN(running,3736) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:38:10 ago, cause: software
    Last software reset at 2020-01-09 17:26, reason: Assertion failed, spinning module Platform, available RAM 11212 bytes (slot 2)
    Software reset code 0x4090 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0x20004b24 Task 0x4e49414d
    Stack: 000001a7 00462974 00445543 20002c54 0044d6d1 20002c54 00000000 00000000 ffffffff 20002c54 20003258 0026de28 8e471f13 00462424 a5a5a5a5 a5a5a5a5 0044d87f 20002c48 20004b80 00000000 0044be67 20002c20 004403e7
    Error status: 0
    MCU temperature: min 33.1, current 33.3, max 33.6
    Supply voltage: min 12.6, current 12.7, max 12.8, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-01-09 18:04:11
    Slowest loop: 1.11ms; fastest: 0.07ms
    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
    === DDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Segments left: 0
    === Network ===
    Slowest loop: 200.63ms; fastest: 0.08ms
    - WiFi -
    Failed messages: pending 0, notready 0, noresp 2
    WiFi MAC address 84:0d:8e:b3:b0:4d
    WiFi Vcc 3.39, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 22744
    WiFi signal strength -59dBm, reconnections 0, sleep mode modem
  • ok i think this is a topic for @dc42
