Ender 3 Configuration
Hello all,
I am trying to install a Duet Wifi 2 on an ender 3 with Inductive Probe and Filament detection via a simple endstop switch.
I am trying to use the stock LCD and emable crash detection/endstopless homing. I am a bit lost in the configuration as I am not able to get these settings to work. Does the board support the LCD yet? How can I get the endstopless homing to work? I am a stranger to Reprap firmware config tool, but I have lots of experience with endstopless homing in Marlin with tmc 2130/2209. Any help is appreciated, and looking forward to getting things working!
Happy Printing,
D Milan -
there is a step by step guide
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37 -
Keep it simple to start with. Follow that guide to get yourself up and running with endstops. By then you will be more comfortable with RRF, and can start to add in things like the probe and sensorless homing.
Familiarize yourself with the documentation and come back with any specific questions and problems you may have.
https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
FYI, You cannot use the Stock LCD with a Duet2 WiFi.
IIRC Duet Maestro Only to be able to use the stock LCD 12864.HTH Paul.
