    Flickering led on Smart Effector probe
    • Gunnarsundefined
      Gunnars
      There is a flicker on the probe led after updating to firmware 3. This problem I did not have before. I can probe without any problem when the nozzle is cold, as soon as it reaches 190 celsius it starts to flicker and I cant probe(Error: Z probe already triggered at start of probing move). If I jog halfway up the towers (Delta Duet WiFi) the led goes off. I have changed all the cable to rule out the possibility of a bad connection.
      The code is from RRF Config Tool
      M558 P5 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 R85 S20 ; define mesh grid
        I am fairly sure that is caused by a bad connection, most likely a bad crimp connection in the +3.3V or ground wire to the 8-pin connector, but possibly a bad solder joint on the effector.
        • JuJuDeltaundefined
          JuJuDelta
          I had a similar problem, it was fluff on the cooling fan causing imbalance and vibration. Only present when thermostatic fan came on with higher nozzle temp.
          T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
          • Gunnarsundefined
            Gunnars
            Still no success. I changed the PCB but the problem persists. Then I noticed that if the heat bed was switched off then the probing went really well if the heat bed was sett to 0 degrees and up it was not possible to probe without getting P1000. The problem that remained was that when I was going to print, the nozzle went straight down into the heat bed and started printing at around -5mm and I had to use babystep to get up to 0. I had hoped the upgrade to the latest firmware 3.01 would solve the problem but did not. Now when I start the printer shows P1000 the led is not on. Any thoughts about what it might be?
              dc42 administrators @Gunnars
              @Gunnars said in Flickering led on Smart Effector probe:
              It sounds like either your bed heater is generating very large magnetic fields, or you have a grounding problem or a PSU problem. What sort of bed heater is it?
              What do you have the trigger height set to in your G31 command? It should be about Z-0.1.
