    3 independent Z motors issue
    142
    • cugetare
      cugetare last edited by
      Hello
      I usually research a lot before posting a question, this is why this is my first post.
      I’ve built myself a pretty stable core xy, until I decided to upgrade to linear rails which turned out good however I have a slight Y tilt sensitivity which I thought I can correct it easily by adding a 3rd Z motor.
      My problem is that one of the lead screws has a different pitch, which requires different steps/mm for the new motor.
      I did find a solution, to define the 3rd motor into a new axis, U, and define the new steps/mm accordingly. Did it, tested it separately and works fine, as an independent motor.
      What I cannot figure out is how make the U motor move when I issue a Z command, like when jogging Z in DWC.
      Any help or hint is highly appreciated.
      • DIY-O-Sphere
        DIY-O-Sphere last edited by
        Haven't you found that guide?
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_Example_for_3_motors
        • cugetare
          Cheers for the reply. Of course I've seen it... But it doesn't necessarily fix the issue... if i would apply this guide I would lose the ability to jog Z, well i could but it would just move the motors assigned to Z... and what still eludes me.. how would this behave in a print... would i have to do some settings in my slicer?
          I believe normally i could just declare 3 motors to the Z is they would be the same and have the same kind of lead screws, but if i declare a new axis for the third motor, this would mean that whenever Z is mentioned U must follow... and I wounder if it would be a simpler solution to this, like U just follows any Z movement. It would have been a lot easier if Z would allow for different steps/mm like E does.
          Here is a rough sketch of my configuration:
          Z1 and Z2 have an 4mm/rev screw, motor is 1,8 deg which results in 800 steps/mm
          Z3 is a 2mm/rev on 1.8deg which leads to 1600 steps/mm
          And this is a snippet form my config.g
          M569 P0 S1                                         ; Drive 0 goes fwd
          M569 P1 S1                                         ; Drive 1 goes backwards
          M569 P2 S0                                         ; Drive 2 goes backwards
          M569 P3 S1                                         ; Drive 3 goes backwards
          M569 P4 S0                                         ; Drive 4 goes backwards
          M569 P5 R1 T2.5:2.5:5:0 S0                        ; External Drive 5 goes backwards
          M584 X0 Y1 Z2:4 U3 E5 				   ; two Z motors connected to driver outputs Z and E1 and two E motors E0 and E2
          M350 X16 Y16 Z16 U16 E16 I1                            ; Configure microstepping with interpolation
          M92 X160.00 Y160.00 Z798.8 U1600		   	   ; Set steps per mm for XYZ
          M92 E396	               			   ; Set steps per mm for extruders
          M566 X800.00 Y800.00 Z12 U12 E300 		           ; Set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z600 U600 E2400 	           ; Set maximum speeds (mm/min)
          M201 X1500.00 Y1500.00 Z20 U20 E1500 	           ; Set accelerations (mm/s^2)
          M906 X1200.00 Y1200.00 Z1200 U1200 E800 I30     	   ; Set motor currents (mA) and motor idle factor in per cent
          With this I get the possibility to jog U axis in the main screen (which i can suppress with P3 in M584 ) but Z movements are not reflected in Z3 motor (which is mapped to U)
          DIY-O-Sphere 1 Reply Last reply Reply Quote 0
          • Veti
            Veti last edited by Veti
            @cugetare said in 3 independent Z motors issue:
            they have to have the same number of steps /mm, try reducing the microstepping on the external motor by a factor of 2
              RRF doesn't directly support multiple motors on an axis with different steps per mm. But I think you could make it work by defining the additional motor as a U axis and then using the M669 command Z parameter to adjust the matrix to make the U motor move by the correct amount when you move Z. You can hide the U axis in normal use.
              cugetare 1 Reply Last reply Reply Quote 0
              • DIY-O-Sphere
                DIY-O-Sphere @cugetare last edited by
                As I’m planning the modification of my Z-axis, I have just looked in this thread.
                Standard seems to be realy easy, but I had not realized that M92 is related to the axis and not to the drives.
                No hard feelings.
                • cugetare
                  cugetare @dc42 last edited by
                  @dc42 said in 3 independent Z motors issue:
                  Thanks for the hint DC.
                  I assume i should define M669 K5 (CoreXYU) X1:0:0 Y0:1:0 Z0:0:1 U0:0:0.5
                  Right?
                    dc42 administrators @cugetare last edited by
                    Right?
                    If it's a Cartesian machine and you set up Z and U with the correct steps/mm in both cases, then I think you want X1:0:0:0 Y0:1:0:0 Z0:0:1:1 U0:0:0:1. Then use M584 P3 to hide the U axis.
                    • cugetare
                      Right?
                      Hi DC
                      I tried your advice and the movement looks better (did some changes though i have a coreXY). Sorry for the delay, i ran into some issues with the bed probing, looks like EMF in the cable is not appreciated by BLTouch. some rewiring and some ferrites later i could make a foolish attempt at homing the thing... which kind of fails... i will paste my config and my homing files hoping someone can point me to the mistake i overlooked.
                      I can explain a little about the behavior. My setup was configured with senseless homing for X and Y so the machine would first home X then Y then go in the middle of the bed and home Z.
                      NOW.... after XY homing head is positioning in the middle of the deploying the probe waiting for the bed to touch it, Z(with 2 motors) and U(with 1 motor) are moving in sync until BLTouch is triggered, but sometimes U continues to move... I know i'm making a mistake... i just don't see where....
                      This is my config.g as of now
                      G90                                                ; Send absolute coordinates...
                      ;M667 S1                                            ; Select CoreXY mode
                      M669 K5  X1:1:0:0 Y1:-1:0:0 Z0:0:1:1 U0:0:0:1		; custom axes
                      ; left out
                      M584 X0 Y1 Z2:4 U3 E5 P3			   ; two Z motors connected to driver outputs Z and E1 and two E motors E0 and E2
                      M350 X32 Y32 Z16 U16 E16 I1                            ; Configure microstepping with interpolation
                      M92 X320.00 Y320.00 Z798.8 U1600		   	   ; Set steps per mm for XYZ
                      M671 X-50:150:340 Y140:320:140 S3        ; leadscrews at left and right of X axis
                      M208 X-28:280 Y0:300 Z0:250 U0:250	 ; axis min and max
                      M574 X1 Y1 S3                                      ; Set active low endstops
                      M915 P0 P1 S3 F0   				   ; configure stall detection
                      M307 H3 A-1 C-1 D-1 				             ; Disable the 3rd Heater
                      M574 Z1 U1 S2                                                  ; Set endstops controlled by probe
                      M558 P9 H5 F1000 T12000		             ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
                      G31 X0 Y25 Z2.1 U2.1 P25	                             ;  Set Z probe trigger value, offset and trigger height
                      M557 X27.5:286 Y5:285 S80                            ; Define mesh grid
                      M307 H0 B0 S1.00 F50                                   ; Disable bang-bang mode for the bed heater and set PWM limit
                      M143 H0 S140                                                 ; Set temperature limit for heater 0 to 120C
                      M143 H1 S280                                                 ; Set temperature limit for heater 1 to 280C
                      ; My Fans
                      M106 P0 S0.3 I0 F200 H0 T45                          ; Set fan 0 value, PWM signal inversion and frequency. TC -> ON
                      M106 P1 S0.5 I0 F200 H1 T85                          ; Set fan 1 value, PWM signal inversion and frequency. TC -> ON
                      M106 P2 S0.3 I0 F200 H0 T45                          ; Set fan 2 value, PWM signal inversion and frequency. TC -> ON
                      M563 P0 D0 H1 F0:2                                ; Define tool 0
                      G10 P0 X0 Y-20 Z0                                   ; Set tool 0 axis offsets
                      G10 P0 R0 S0                                      ; Set initial tool 0 active and standby temperatures to 0C
                      ; Automatic power saving
                      M911 S20 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                      M501                                            ; Load saved parameters from non-volatile memory
                      T0                                                 ; Select first tool
                      M280 P3 S120 I1                        ; BLTouch force self test
                      G4 S2                                           ; for 2 secs
                      M280 P3 S90 I1                          ; then retract
                      This is my homeall.g as of now
                      G91            		; relative positioning
                      G1 S2 Z5 F200 		; lower Z relative to current position
                      G90            		; absolute positioning
                      M98 P/sys/homex.g
                      M98 P/sys/homey.g
                      G1 X150 Y150 F6000          		; go to first bed probe point and home Z
                      G30 S-1                    		; home Z by probing the bed
                      G92 Z2.1  ;U2.1
                      G1 H2 Z5 U5 F100
                      G1 X0 Y0 F6000         	; go back home XY
                      Homex.g (home y is the same but for y homing)
                      M400					; make sure everything has stopped before we make changes
                      M915 P0:1 S3 F0 R0			; configure stall detection
                      M574 X1 Y1 S3				; set endstops to use motor stall
                      M913 X50 Y50				; reduce motor current to 50% to prevent belts slipping
                      M201 X500				; reduce acceleration to avoid false triggering
                      G91					; use relative positioning
                      G1 S1 X-325 F4000		      	; move towards axis minimum
                      G1 X5                      		; move away from home
                      M400                  			; make sure everything has stopped before we reset the motor currents
                      M913 X100 Y100 				; motor currents back to 100%
                      G90                   			; back to absolute positioning
                      M574 X1 Y1 S1
                      homez.g
                      G92 Z2.1 ;U2.1
                      G1 H2 Z5 U5 F100
                      • cugetare
                        I think this looks like a needle in hay stack kind of thing so let me simplify my doubts...
                        After defining the U axis with
                        And specifying the motor assignments and steps pr mm:
                        M92 X320.00 Y320.00 Z798.8 U1597.6		   	   			; Set steps per mm for XYZ
                        then speed, jerk, acc
                        Should i also mention U in:
                        • axis limits?
                        M208 X300 Y300 Z0 U0 S0 								; Set axis maxima
                        M208 X0 Y0 Z250 U250 S1 								; Set axis minima
                        • Z probe config?
                        G31 X0 Y25 Z2.1 U2.1 P25	    ; actual 1.635 Set Z probe trigger value, offset and trigger height
                        • home Z?
                        • bed.g?
                          In other words, should i mention U every time Z is also mentioned?
                          • axis limits?
                          • Z probe config?
                          • home Z?
                          • bed.g?
                          I suggest this:
                          • Define the U axis in M584 in config.g. Initially, don't hide it.
                          • Set the current, microstepping and steps/mm of all drives including U.
                          • Then hide U (M584 P3). After that, never mention U again.
                          Here's an alternative that doesn't involve a U axis, based on your steps/mm ratio being 2:1:
                          • Define 3 axes and 3 Z motors
                          • Set the currents, microstepping etc. with the microstepping set to be correct for the U axis
                          • Redefine Z as having only 2 motors
                          • Change the Z microstepping by a factor of 2 so that those 2 motors now have the same steps/mm as the third one
                          • Redefine Z as having 3 motors. After that, don't change the microstepping again.
                          Caution: if VIN power is lost (under voltage event) but the board doesn't reset, all 3 drives will be reprogrammed with the same microstepping. So I suggest you do the above sequence in homez.h and in homeall.g.
                          • cugetare
                            Thanks a lot for the help, I was actually thinking that micro-stepping could be the answer but i would have never figured it out alone how exactly to to that. i added the following 3 lines after removing all mentions of the U axis and switching back to M667 S1
                            M584 Z2:4
                            M350 Z32
                            M584 Z2:3:4
                            works like a champ! even tested the leadscrew self adjustment and works perfectly.
