BL TOUCH CONFIGURATION
  • HI ,
    i'm new with my DUET 2 wifi V1.04 and try to confirgure my Alfawise U20 with it.
    i'm running:
    Duet 2 wifi 1.04
    3.0 firmware
    new BL Touch
    i've follow all the tutorials to configure the BL touch, but still nothing , and i've try many things, my BL touch is plug into:
    z probe in/ GND for Z probe
    +5v/GND and Pin8 HEATER3 for the servos cable
    i've try many change on the file config.g but nothing seems to work and the command S10, S120 result on a bad command in the DWC.
    here my config.g:
    M574 X1 S0 P"xstop" ; configure active-low endstop for low end on X via pin xstop
    M574 Y1 S0 P"ystop" ; configure active-low endstop for low end on Y via pin ystop
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
    M558 P9 C"zprobe.in" H3 F120 T4800 ; set Z probe type to bltouch and the dive height + speeds
    M558 H30 ;*** Remove this line after delta calibration has been done and new delta
    parameters have been saved
    G31 P25 X-35 Y10 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X15:285 Y15:285 S20 ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4700 ; configure sensor 0 as thermistor on pin bedtemp
    M143 H0 S70 ; set temperature limit for heater 0 to 70C
    M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
    M308 S1 P"e0temp" Y"thermistor" T100000 B4700 ; configure sensor 1 as thermistor on pin e0temp
    M143 H1 S230 ; set temperature limit for heater 1 to 230C
    M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
    my deployprobe.g:
    M280 P0 S10 I1 ; deploy BLTouch
    my retractprobe.g:
    M280 P0 S90 I1 ; retract BLTouch
    did you have some idea of what happen? how to solve.
    thanks
    christophe
  • @christophe31 said in BL TOUCH CONFIGURATION:
    You have to invert the input
  • Also remove the I commands from deployprobe.g and retractprobe.g
  • @christophe31
    Please also check the homez.g and the homeall.g. if the G30 is included.
    Otherwise the probe will not be deployed and retracted in the homing moves.
  • @DIY-O-Sphere said in BL TOUCH CONFIGURATION:
    when i delete the " ^ "it's the same issue will look at the other files you say and come back
  • here my homeall.g:
    G91 ; relative positioning
    G1 H2 Z5 F4800 ; lift Z relative to current position
    G1 H1 X-305 Y-305 F6000 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F4800 ; go back a few mm
    G1 H1 X-305 Y-305 F600 ; move slowly to X and Y axis endstops once more (second pass)
    G90 ; absolute positioning
    G1 X50 Y5 F4800 ; go to first bed probe point and home Z
    ;G91 ; relative positioning
    ;G1 Z5 F80 ; lift Z relative to current position
    ;G90 ; absolute positioning
    and my homez.g:
    G1 X50 Y5 F4800 ; go to first probe point
    Witch RRF3 version are you using.?
    For the stable you have to remove this
    Wtch RRF3 version are you using.?
    For the stable you can remove this
    yes i've remove this line
    allelluia my Z homing fonctionning... THANKS A LOT one who know here better than 100 who search..
    the only issue i have is that the homing for the Z is not in the center of my bed, did you know the line to correct?
    Adept those lines in both homing files
    yes found everything seems to work fine, thanks a lot again, for your fat answer.
    i'm too happy lol:)
    i'm too happy lol:)
    You are wellcome
