    Duet2Wifi Laser Diode (2pin Power + 2 pin TTL type) hook up
    Laser Cutters
    143
    • otaku521
      otaku521 last edited by
      Dear All
      I know that many have asked the same questions on wiring up a laser - but most I saw are 3 pin type (+/-/PWN) ... but I have 2 x 2 pins type (one 12v another 5v for ttl)
      Knowing that there might be a need for a 74hct02 to do this, but there were comments that a Duet expansion board can do in place of this? (sorry getting bits and pieces of info left and right and got confused)
      I have 12 v plugin into PSU for Duet and laser diode seperatly ( sorry if the drawing on the pic is a lil confusing)
      how would this plug up? 3 pins on heater while ttl have only 2... can anyone pls help?? thanks!
      TonyW
      A Former User dc42 2 Replies Last reply Reply Quote 0
      • A Former User
        A Former User @otaku521 last edited by
        Hook the 5v ttl up a a 5v fan output? You may need to invert the pin in configuration if laser is on when it should be off. (Be aware this can also result in sort burts of laser when starting up, so wear goggles at all times the machine has power)
        And the 12v to a 12v supply?
        • otaku521
          hooking it to fan... will it still work with g1 sxxxx like commands? if so how to declare it? can you help? how to invert the pin config? using "i1"?
          Yes 12v plug goes directly to 12v supply
          DeltaCon 1 Reply Last reply Reply Quote 0
            dc42 administrators @otaku521 last edited by
            @otaku521 said in Duet2Wifi Laser Diode (2pin Power + 2 pin TTL type) hook up:
            Leave the +5V pin on the 3- pin servo connector unconnected.
            otaku521 1 Reply Last reply Reply Quote 0
            • otaku521
              otaku521 @dc42 last edited by otaku521
              @dc42 Thanks! To further the question:
              So I plug + on laser diode to heater 7 pwm and - to GND?
              laser seems doesn't fire...
              Here is my config.g:
              M667 S1 ; Select CoreXY mode
              G21 ; milimeter Mode
              M550 PLaserMk1 ; Set machine name
              M551 PXXXXXXXX ; Set password
              M587 S"XXXXXXXX" P"12345678" ; Configure access point. You can delete this line once connected
              M552 S1 ; Enable network
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M569 P0 S0 ; Drive 0 goes BACKWARDS (X)
              M569 P1 S0 ; Drive 1 goes BACKWARDS (Y)
              M584 X0 Y1 ; Drive 0-X 1-Y
              M350 X16 Y16 I1 ; Configure microstepping with interpolation(I=1) (x16 from 16)
              M92 X80 Y80 ; microstep 16 Interpol 256
              M201 X1000 Y1000 ; Max Accerlation (mm/min)
              M203 X24000 Y24000 ; Maximum speeds (mm/min)
              M566 X1200 Y1200 ; jerk values
              M906 X900 Y900 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S50 ; Set idle timeout
              M208 X0 Y0 S1 ; Set axis min
              M208 X220 Y210 S0 ; Set axis max
              M574 X1 S1 ; Set active High endstops (S1=SENSORED) (X-MIN(1)) (S3=SENSORLESS)
              M574 Y1 S1 ; Set active High endstops (S1=SENSORED) (Y-MIN(1)) (S3=SENSORLESS)
              ; LASER SETTINGS
              M563 P0 D-1 H-1 ; clear tool
              M563 P0 D0 ; create a tool - no heaters
              M307 H6 A-1 C-1 D-1 ; Clear Heater 7
              M452 P6 R255 F500 I0 ; switch to laser mode using Heater 7 PWM to control the laser
              G10 P0 X0 Y0 ; Set tool 0 axis offsets
              T0 ; Select first tool
              Here is my homeall.g
              M400 ; make sure everything has stopped before we make changes
              G91 ; relative positioning
              M400
              G1 H1 Y-300 F2800 ; move quickly to X or Y endstop and stop there (first pass)
              M400
              G1 Y20 F2800 ; Move Away 20mm X axis
              M400
              G1 H1 X-305 F2800 ; move quickly to X or Y endstop and stop there (first pass)
              M400
              G1 X20 F2800 ; Move Away 20mm X axis
              M400
              G92 Z0 ; No Z, Home "Z"
              • otaku521
                @dc42 updated wiring
                • otaku521
                  Dear everyone,
                  is the above correct? (wiring and config)
                  much appreciated
                  Thx
                  Tony
                  • DeltaCon
                    DeltaCon @otaku521 last edited by
                    Did you ever get this question answered? I find myself having the same question. Since Duet boards can be jumpered to give 5V on the fan output, that seems like an ideal method for connecting a laser. But there is so much contradicting information about this topic. Having g1 sXXX comands (Grbl style) is by far preferable indeed.
                      dc42 administrators @DeltaCon last edited by dc42
                      Dear everyone,
                      much appreciated
                      Did you get this working? The only think I can see wrong is that you have used the heater 7 output on the breakout board, but P6 (instead of P7) in the M452 command in config.g.
                      @DeltaCon said in Duet2Wifi Laser Diode (2pin Power + 2 pin TTL type) hook up:
                      Except that the laser would be on at power up, until the Duet executes the command to configure that fan and turn it off.
                      Another (safer) way to drive a laser would be to pick up the 5V signal from the gate of one of the heater output mosfets; but this would void the warranty on the Duet.
                      Yes, which is why RRF supports those commands.
                      • DeltaCon
                        DeltaCon @dc42 last edited by
                        @dc42 said in Duet2Wifi Laser Diode (2pin Power + 2 pin TTL type) hook up:
                        Thanks DC, I will look into that.
                        Perhaps it would be a nice idea, in a future revision of the board, to add a set of pins, shared with a heater, specifically for connecting a laser. There are quite many questions on the forum about lasers, and it would prevent people from using lesser safe methods or voiding warranty.
                        Some years ago I upgraded ma RMaxv2 with a duet board and trashed the Rambo. Now I am building a laser CNC machine, I thought I could reuse that Rambo board, but this Arduino, Marlin and Grbl stuff is really terrible to wrap your head around once you are used to Duet configurations 😉
                          We have done this on the Duet 3 main board starting from revision 1.0.
                          • DeltaCon
                            That's great, but I don't think I can get a Duet 3 for the price of a Maestro plus a JST connector 😉 (meaning that this is a BIG stepup pricewise). Apart from the laser connection, a Maestro is by far powerful enough to handle a simple XYYZ machine I think.
                              The replacement for the Maestro that we have started designing will have a suitable output for driving lasers with TTL-compatible inputs.
                              • DeltaCon
                                That's good news!
                                I would not hold my breath would I?
                                  That's good news!
                                  No, it will be several months before it is in production. It will almost certainly cost more than the current Maestro, but it will have a higher specification.
