”The last HTTP request has timed out.”
  • Hi Forum
    I hope you can help me with the following.
    My printer was working, until this error started appearing
    Apparently the disconnect happends when the extruder starts to heat.
    My heatbed is 220V and doesn´t trigger a disconnect.
    M122
    Used output buffers: 3 of 32 (16 max)
    RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-956GU-DJ3S0-7J9FD-3SJ6K-KAGVF
    Static ram used: 16152
    Dynamic ram used: 100896
    Recycled dynamic ram: 1736
    Stack ram used: 1224 current, 4504 maximum
    Never used ram: 7784
    Last reset 00:05:09 ago, cause: power up
    Last software reset at 2020-01-12 19:59, reason: User, spinning module GCodes, available RAM 7888 bytes (slot 1)
    Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
    Error status: 0
    Free file entries: 10
    MCU temperature: min 39.5, current 39.6, max 39.9
    Supply voltage: min 24.6, current 24.7, max 24.9, under voltage events: 0, over voltage events: 0
    Date/time: 2020-01-13 10:59:13
    Slowest main loop (seconds): 0.155631; fastest: 0.000116
    MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 0, completed moves: 0
    Bed compensation in use: none
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.21RC4(08b3)
      WiFi MAC address 5c:cf:7f:76:64:25
      WiFi Vcc 3.37, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 16216
      WiFi IP address 192.168.38.100
      WiFi signal strength -54dBm, reconnections 0, sleep mode modem
      Socket states: 2 0 0 0 0 0 0 0
      === Filament sensors ===
      Extruder 0 sensor: position 0.08, ok, framing errors 0, parity errors 0, no calibration data
      === Expansion ===
    Thank you
    //Poul Erik
  • @Poul-Erik said in ”The last HTTP request has timed out.”:
    1
    the first thing i would try is to update the duetwifi you running v 1.x we are now on v 3.x try to update to 2.05 first and check again if this working then you can go to v3.x
  • Hi Slam
    Thank you, I´ll update and see what happends.
    //pe
  • When coming from such an old firmware definitely read the release notes. There will be some changes to your config required. I would suggest staying with 2.05 to start with. There will be enough major changes between 1.20 and 2.05 to keep you busy. The change to 3.x is even more substantial configuration wise.
    There has been a lot of work and fixes on wifi firmware and DWC between then and now, so your issue may have already been fixed.
  • Hi Phaedrux
    Thank you for your reply.
    I looked through the changes for version 3 firmware and it surely looks "substantial"!
    Where can I download the 2.05 build? I can´t see it on GitHub. Can you point me to it?
    Thanks
    // Poul Erik
  • It should be below the 3.x releases a bit.
    https://github.com/dc42/RepRapFirmware/releases/tag/2.05
    Your WiFi firmware in particular is old. I suggest you upgrade DuetWiFiServer to latest version.
  • Hi DC42
    Thank you for your comment.
    I will update the DuetWiFiServer first, and afterwards update the Firmware to 2,05.
    //Poul Erik
  • Thank you @Phaedrux
    I have updated the printer and I am working on the config.
    //pe
  • Hi @Phaedrux
    What is the preferred way to update the config file?
    I am intimidated by the sheer amount of changes, and worried to overlook something!
    Will I have to read through all changes from my previous firmware, as they are listed here?
    https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
    Or is there a summary somewhere, with relevant changes for 3d printers or even for Delta printers?
    Kind Regards
    //Poul Erik
  • Yes it's a good idea to read through the what's new page. Or at least skim it for things that seem relevant. The biggest changes for each version are called out at the start usually.
    If after going through that you're not sure what to do, you can post your current config file set in a new thread and get some feedback on what should be changed.
