RRF3 and dual sensors for heat bed
  • It seems that I have had good luck sorting out my migration to RRF3 only two issues remain. I have not been able to get the BLTouch to work but that needs some more digging before I ask for help.
    The second issue, I have two thermistors on my heat bed, one to actually get and control the temperature with and one that I would just like to display on the temperature graph.
    I use the following to specify the sensors (and heaters):
    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
    M308 S0 P"e2temp" Y"thermistor" T100000 B3950 ; configure alternate or second bed heat sensor
    M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
    M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
    M307 H1 B0 S0.6 ; disable bang-bang mode for the nozzle heater and set PWM limit
    M308 S2 P"e1temp" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin e0temp
    M950 H2 C"e1heat" T2 ; create nozzle heater output on e0heat and map it to sensor 2
    M143 H2 S280 ; set temperature limit for heater 2 to 280C
    M307 H2 B0 S0.6 ; disable bang-bang mode for the nozzle heater and set PWM limit
    I question the S0 on line 1 and line 2 - should they be different sensors ?
    I tried to make line 2 S3 instead of S0 but that didn't result in a line on the temperature graph.
    How do I display the second sensor on the temperature graph
  • Never mind, sorted it out. Kinda non-intuitive but it turns out you have to give a name (A parameter in M308) to the sensor and then you can go to the 'extra' tab in the heaters in the web interface and select to display the graph.
  • <sigh> Ok, so I named the two sensors 'test1' and 'test2' to see if they would show up .... and they did. Now, no matter what I name them, the graph always names them test1 and test2. The name reflects properly under tools extra but is not re-named to the new name in the graph. Bug ? or do I need a magic incantation ?
  • When saving the config.g file, the system asks you if you want to restart Duet. When you answer 'yes' it does a reset but it doesn't clear the name of the graph in the chart window that was changed. Instead, a refresh of the web page is required to reset the name to the name that is specified in config.g
    In other words, it's a bug.
  • While I am talking to myself here and reporting bugs .... the temperature chart shows a dashed line for the extra sensor but the legend on the graph shows some weird thing that might have some relation to a dashed line before it fell into a pot of chocolate andScreenshot from 2020-01-14 00-54-12.png had to eat it's way out of it getting real fat in the process (sorry, that's the only way that I can describe it)
