M999 - sometimes gives 'Operation Cancelled' message
  • This is happening intermittently.
    SOnetimes it works, sometimes it doesn't.
    Sometimes when I have changed config.g and select 'yes' to reset the duet it will do the operation, sometimes it comes back with m999 operation canceled.
  • can you please provide more information? which board? which firmware? config.g ?
  • It's a duet2 wifi board and I am in the process of upgrading from RRF2 to RRF3. The issue has never occurred in RRF2. I mostly noticed it when editing the config.g file, saving it and answering 'yes' to the question of restarting the Duet. The issue also happens when manually issuing a 'M999' command.
    config(1).g
    It seems unrelated to config.g, sometimes it flakes out and other times a reset works fine. Anyway, I have attached the latest config.g file.
  • why you do
    M350 X16 Y16 Z16:16 E256:256 I1 ; Configure microstepping with interpolation for x,y,z,E0 and E1
    Interpolation only works with 16 Steps not with 256
    in your config:
    M106 P0 S0                     ************************            ; set fan 0 value .
    ; old code from RRF 2
    ; set up for piezo z probe
    ;M558 P8 I1 R0.3 F600 H10 T3000     	   	  ; Digital mode (P5), active high (I1), delay (R0.3), speed (F600), dive height (H5), probe up to 4 times (A4) for at least two consecutive consistent ;readings,travel speed (T8000)
    ;M558 P1 I1 R0.3 F300 H5 A4 T8000
    ;M558 P1 I1 R0.3 F300 H5 T8000
    ;;G31 P500 X11.0 Y0.5 Z1.65 ; set threshold and offsets
    ;The XYZ parameters in the M558 command define which axes the Z probe is used to home (0 = Z probe not used to home this ;axis, 1 = Z probe used). By default, RepRapFirmware for the Duet 0.8/0.8.5 (but not ;the Duet 2) uses the Z probe to home ;the X and Z axes.
    ;The H parameter defines the Z probe dive height, which is the height above the trigger height from which probing starts. ;The default is 3mm or 5mm depending on firmware version. You may wish to increase it ;during initial calibration.
    ;G31 X0 Y0 Z-0.18 P474                              ;probe X, Y, Z offsets (all zero = first nozzle), might use x+10 for the spot between the nozzles, Trigger point of probe
    						   ; G31 must come after M558
    						   ; Z should normally be slightly negative as the probe triggers just below zero
    ; correct for proper MMU temperature
    bevore the stars missing a ; semicolon
    after the error operation canceled type in the g-code console M122 and post the result
  • @SIam said in M999 - sometimes gives 'Operation Cancelled' message:
    why you do
    Yes, I am aware of that. This is what I had in RRF2 and I assume the interpolation gets ignored for the extruders.
    in your config:
    Awesome catch - thanks !
    The damn thing is working at the moment. I will keep trying to catch it when it faults out.
  • There we go:
    m122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later + DueX5
    Board ID: 08DGM-917DA-G4MS8-6JKD0-3SD6M-KTSRA
    Used output buffers: 3 of 24 (7 max)
    Static ram: 30516
    Dynamic ram: 93004 of which 0 recycled
    Exception stack ram used: 216
    Never used ram: 7336
    Tasks: NETWORK(ready,1048) HEAT(blocked,1184) DUEX(suspended,160) MAIN(running,3676) IDLE(ready,156)
    Owned mutexes:
    Last reset 00:00:14 ago, cause: software
    Last software reset at 2020-01-14 14:06, reason: User, spinning module GCodes, available RAM 7252 bytes (slot 1)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    Error status: 0
    Free file entries: 10
    MCU temperature: min 29.8, current 30.2, max 30.6
    Supply voltage: min 24.3, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 5: standstill, SG min/max not available
    Driver 6: standstill, SG min/max not available
    Driver 7: standstill, SG min/max not available
    Driver 8: standstill, SG min/max not available
    Driver 9: standstill, SG min/max not available
    Cache data hit count 28385061
    Slowest loop: 1.51ms; fastest: 0.10ms
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    === AuxDDARing ===
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 15.44ms; fastest: 0.01ms
    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
    HTTP sessions: 2 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.23
      WiFi MAC address b4:e6:2d:52:ef:1f
      WiFi Vcc 3.43, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 26096
      WiFi IP address 192.168.1.114
      WiFi signal strength -46dBm, reconnections 0, sleep mode modem
      === Filament sensors ===
      Extruder 0 sensor: no filament
      Extruder 1 sensor: ok
  • I also noted the last two lines re filament sensors - the web panel shows neither one of the sensors as active which I posted about on another thread.
  • Just a closing remark to this thread ..... apparently the M999 error message was a known bug in the web interface and has been fixed in version 2.06
