    After Firmware update on Duet 2 Ethernet from 2.04 to 3 Error
    137
    • goodchrhere
      goodchrhere last edited by
      Hello
      After update on Duet2 Ethernet i have a Problem when i heating the Bed.
      It show me an error: Heating fault on heater 0 temperature rising more slowly than the expected 0.8°C/sec.
      here my config:
      ; generated by RepRapFirmware Configuration Tool v2.1.7 on Wed Jan 15 2020 14:35:10 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 P"Deltawasp 2.0" ; set printer name
      M665 R175 L295 B110 H416 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P3 S0 ; physical drive 3 goes backwards
      M350 X256 Y256 Z256 E64 I0 ; configure microstepping without interpolation
      M92 X1350.00 Y1350.00 Z1350.00 E663.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1600.00 ; set accelerations (mm/s^2)
      M906 X1600 Y1600 Z1600 E1000 ; set motor currents (mA)
      M84 S0 ; Disable motor idle current reduction
      M208 Z0 S1 ; set minimum Z
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
      M558 P0 H0 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 R85 S20 ; define mesh grid
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M563 P0 D0 H1 F-1 ; define tool 0
      • jay_s_uk
        jay_s_uk last edited by
        Have you re PID tuned it?
        M303 H0 S70
        for example
        goodchrhere 1 Reply Last reply Reply Quote 1
        • goodchrhere
          No, i will do it now. Thanks, i will reply after
          • goodchrhere
            goodchrhere @jay_s_uk last edited by
            @jay_s_uk Thanks, it works. i'm stupid xD
              dc42 administrators @goodchrhere last edited by dc42
              @goodchrhere said in After Firmware update on Duet 2 Ethernet from 2.04 to 3 Error:
              No you're not, it's something I overlooked. In RRF2 the bed heater used to default to bang-bang and a different heater model from the extruder. But RRF3 doesn't know how you will use a heater when you create it, so the default heater parameters are OK for some extruders but don't suit most beds. This means you might get away with not tuning the bed heater in RRF2, but you probably won't with RRF3.
              • goodchrhere
                okay i understand, it work by the 3d printer in the company. At home i have the same problem. I tuned the bed, and it will be heat up. but when i set 50° for bed, it will heat. After to reach 50° the voltage from 12V goes down to 9.5V. I have a 12V bed with a ssr.
                The heatbed https://www.3dware.ch/MK3-Alu-Heizbett-400mm-x-300mm-De.htm
                The ssr: https://www.aliexpress.com/item/32756137315.html?spm=a2g0s.9042311.0.0.27424c4dRuqXvc
                In rrf2 it works fine and in rrf3 it give an error.
                • goodchrhere
                  Has my bed malfunction, or my ssr?
                  Or have i a false phrase in rrf3?
                  • Danal
                    Danal last edited by
                    This indicates an underlying hardware problem. It may not have been as obvious in RRF2, but it was there.
