    SX1509 on Maestro, does it work?
    Third-party add-ons
    • DIY-O-Sphere
      DIY-O-Sphere last edited by
      I have tried to set up SX1509 on a Maestro, but I don’t get it to work.
      Is it even possible?
      I have set the address
      0x71
      And as the SX1509 has 10k pull up resistors I tried to lower the value by switching 10k in parallel.
      They now are at around 5k
      Pin assignment in config.g (RRF3.01b)
      M950 P1 C"sx1509b.0"
      M950 P2 C"sx1509b.1"
      M950 P3 C"sx1509b.2"
      Tested
      Seams like working, but there is no reaction
      M122
      I am running out of ideas....
        The firmware build for the Maestro doesn't include the SX1509B driver. You can use M260 to access the SX1509.
        DIY-O-Sphere 1 Reply Last reply Reply Quote 0
        • DIY-O-Sphere
          DIY-O-Sphere @dc42 last edited by
          I finally have managed to get it run with M260.
          As the parameters for writing to the data registers aren’t obvious I post my code her for one who is also struggling with that.
          As well it was necessary to calculate the decimal values for some register data.
          The code enables PWM for both banks and writes values for the pins 0-3.
          Sx150 9 and LEDs are wired in sink current mode.
          Test pins 0-3 sx1509.g
