Bed flat at origin,inclined during prob sequence before printing
  • Hi everybody!
    I had finish to build my BLV printer at end when I tried to print square test model It look like same at picture N°1.
    After some research I'd see something strange, when I start printing during probing/compensation sequence, my bed became inclined (see picture N°3), the right side become higher than left side. Before launch my test model in WebUI I had do home all true leveling and home all again, followed by mesh compensation and home all (Picture N°2).
    I adding my printer have two Z axis at left & right sides, left side is minimal X axis and right side is maximal X axis, the back side is Y minimal and front side is Y maximal.
    One more thing strange the 3D Heightmap shown is mirroring, x,y,z mark at back left corner is at good place and front right corner also, but the right back corner and left front corner is permute, right back corner in picture (X30 Y190) on my printer is at left front corner, left front corner in picture (X190 Y30) on my printer is at left front corner. Maybe that's one symptom of the problem.
    I had spend 3 days of my time in this problem and no find when come it and I need urgently my printer print well for my work. I add also some files config.g, bed.g and start script I use in Simplify3D.
    config.g
    ; generated by RepRapFirmware Configuration Tool v2.1.6 on Mon Jan 13 2020 20:14:51 GMT+0100 (heure normale d’Europe centrale)
    M80						; Turns on the ATX power supply
    M667 S1                                            ; select CoreXY mode
    M550 P"BLV mgn Cube"                               ; set printer name
    M587 S"ferguson" P"rearview-picnic-gasp-neff-frays-impotency"            ; Configure access point. You can delete this line once connected
    M569 P0 S0                                         ; physical drive 0 goes forwards
    M569 P1 S0                                         ; physical drive 1 goes forwards
    M569 P2 S1                                         ; physical drive 2 goes backwards
    M569 P3 S0                                         ; physical drive 3 goes backwards
    M584 X0 Y1 Z2 E3                                   ; set drive mapping
    M671 X-25:313 Y150:149 ;gauche X-25 Y150 droite X313 Y149
    M92 X200 Y200 Z400 E415				   ; Set steps per mm for Bondtech. (AJOUT)
    ;M566 X600 Y600 Z24 E200                           ; Set maximum instantaneous speed changes (Jerk) (mm/min) (AJOUT)
    M566 X600 Y600 Z24 E300                            ; Set maximum instantaneous speed changes (Jerk) (mm/min) (AJOUT)
    ;M203 X20000 Y20000 Z600 E2000                     ; Set maximum speeds (mm/min) (AJOUT)
    M203 X20000 Y20000 Z600 E3600                      ; Set maximum speeds (mm/min) (AJOUT)
    ;M201 X3000 Y3000 Z100 E5000			   ; Set accelerations (mm/s^2)(AJOUT)
    M201 X3000 Y3000 Z100 E2000			   ; Set accelerations (mm/s^2)(AJOUT)
    M906 X1600 Y1600 Z1600 E1600 I30                   ; set motor currents (mA) and motor idle factor in per cent
    ; Pressure advance
    M572 D0 S0.55					   ; disabled Pressure advance
    M208 X-21:307 Y-35:302 Z0:649			   ; set axis
    M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
    M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
    ; Filament sensor
    ;M591 D0 P1 C3 S1
    M574 Z1 S2                                         ; Set endstops controlled by probe
    M558 P1 C"zprobe.in" H5 F200 T9000 R0.5            ; set Z probe type to unmodulated and the dive height + speeds
    ;G31 P500 X-2 Y-16.4 Z1.165                         ; set Z probe trigger value, offset of 2 in X and 10 in Y and trigger height
    ;G31 P500 X-2 Y-16.4 Z1.15                         ; set Z probe trigger value, offset of 2 in X and 10 in Y and trigger height
    G31 P500 X-7 Y19 Z1.15                         ; set Z probe trigger value, offset of 2 in X and 10 in Y and trigger height
    M557 X30:260 Y30:260 S80                           ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 R4700 C0    ; configure sensor 0 as thermistor on pin bedtemp
    M143 H0 S100                                       ; set temperature limit for heater 0 to 100C
    M307 H0 A85.0 C236.3 D5.4 V24.0 B0		   ; Set PID for heated bed values
    M308 S1 P"e0temp" Y"thermistor" T100000 B3950 R4700 C0     ; configure sensor 1 as thermistor on pin e0temp
    M143 H1 S260                                       ; set temperature limit for heater 1 to 260C
    M307 H1 A405.7 C118.3 D6.2 V24.2 B0			   ; Set PID for hotend values
    M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
    M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
    M106 P1 S1 H1 T35                                  ; set fan 1 value. Thermostatic control is turned on
    M950 F2 C"fan1" Q500                               ; create fan 2 on pin fan1 and set its frequency
    M106 P2 S1 H1 T35                                  ; set fan 2 value. Thermostatic control is turned on
    ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
    M911 S21 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
    M564 H0                                   	   ; Let the Jog buttons work blv: added to allow jog buttons
    bed.g
    ; bed.g
    ;M561 ; clear any bed transform
    ;G29  ; probe the bed and enable compensation
    M291 P"Probing mesh grid process started" R"Probing.." S1 T2
    G28				; home all axis bb
    G90 				; absolute positioning bb
    M557 X30:260 Y30:260 S80	; Define mesh grid
    G29 S0				; Probe the bed and save height map to file
    M374 				; Save calibration data. Default is sys/heightmap.csv
    M291 P"Probing mesh grid process finished !" R"Probing.." S1 T2
    ; Probe the bed at 4 points X-25:313 Y150:149
    G30 P0 X260 Y149 H0 Z-99999
    G30 P1 X30 Y150 H0 Z-99999
    ;G30 P2 X260 Y260 H0 Z-99999
    ;G30 P3 X260 Y30 H0 Z-99999 S
    ;G28				; home all axis bb
    ;G29 S0
    ;M374 				; Save calibration data. Default is sys/heightmap.csv
    Simplify3D start script
    M291 P"Homing all axis" R"Printing.." S1 T2
    G21		; metric values
    G28		; home all
    ;G29 S2		; mark if you want to disable mesh grid
    G32		; Run mesh grid compenstion
    G29 S0
    		; Purge extruder
    G92 E0 F100		; reset extruder
    G1 Z10 F3000 		; move z up little to prevent scratching of surface
    M98 P/macros/Filament/Purge	; Run nozzle purge macro
    ;G1 E-1 F2000		; Retract 1mm filament
    G92 E0 		; reset extruder
    M291 P"Printing started !" R"Printing.." S1 T3
    Picture N°1
    Picture N°2
    Picture N°3
  • @Sowlan said in Bed flat at origin,inclined during prob sequence before printing:
    you might want to set up
    https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
    change S80 to S10 and see how that looks.
  • @Veti said in Bed flat at origin,inclined during prob sequence before printing:
    Tank you for your fast answer.
    Yes based on wiki I had yet make some changes in config.g for M671 (leadscrews positions) and in bed.g G30 (probe near leadscrews) but maybe you ask to me to focusing on it because my drive mapping show M584 X0 Y1 Z2 E3 and not Z2:4 for independent Z move, I'm intrigue by the fact independent Z move is here yet this's show by this problem and I the case I want static position on Z steppers I think this configuration is good. But is you are any idea about that I take it.
    I had make this change but no really change
    resultats:
    my start test look like this
    Now after press on true leveling button
    and probing sequence before printing
    Please run Mesh bed leveling not true bed leveling.
    without that the duet board can not address the z steppers indepenently so true bed leveling will have no effect.
    i dont quite understand, but as soon as power is off the position can be 2 full steps out of sync.
  • @Veti
    Ok now I understand more clearly the difference between both fonctions. Mesh bed leveling shown me an 29G error due to S10 is too low it tell me to try it S11.5, that's result more what you went, some think look like small ski area for fourmis.
    I have one G32 in my start script Simplify3D, I will delete it, leave G29 S0 and use S50 for grid mesh. and testing to print.
  • The problem hasn't changed
    When I click on Mesh bed compensation button I have this:
    and when I run printing mesh bed compensation change for that and printing result is very bad
  • Same test with S11.5 in M557, it's frustrating 😢
    mesh compensation without printing run
    and now mesh compensation before printing
  • Ok now I know what is the cause of problem but don't know how repair it.
    It's bed heating !!!
    test with bed heating off
    and now with with bed heating on at 60°C....
    Now what about my materials, I using d42 IR sensor with metal plate and modified CR-10 with magnet under it. Somebody know if by reputation something provoke it magnet, hearting, electromagnetism,etc... ?
  • I don't Know if this problem interest any peoples but I continue to investigate...
    Now I tried same test without metal plat, probing on nude surface
    without metal plat and cold bed
    without metal plat and hot bed at 60°C
    If any body know where come from this effect I'm interesting, Maybe @dc42 how have same name than my sensor have an idea?
    I suspect that the bed heat is causing the bed to warp. However, the large amount of variation in your height map indicates that the IR sensor does not work well with your bed surface. What is the bed made of?
  • @dc42
    Hi thank you for you answer, I'd bought BLV kite from Bluerolls at aliexpress the bed I have is here
    it's 310x310mm bed with metal plat and on the plate I have PEI protection.
    Now I suspect something other, the side who falling is connector side, maybe electromagnetism from bed is the problem, I had do speed test with aluminum paper between bed and metal plate, with bed heating I view where the paper exceed out of bed mash map is relatively plate. Now I doing new test with exceed aluminum paper out of bed to view if it's that. I will be busy the next hour but I come soon with result of my test.
  • @dc42
    Finally I have small difference but not significant difference...
    With metal plate, cold bed and paper aluminum border exceed
    With metal plate, hot bed at 60°C and paper aluminum border exceed
