    Running Duet2 Wifi printer without a wireless connection
    • Scrabartundefined
      Scrabart
      I would like to set up my machine in a "demo" mode, where I can print files already on the SD card in an environment where I dont have a wireless network.
      Currently, the popup error messages associated with not having a wireless connection keep showing on the PanelDue 5i and they obstruct the other menu buttons making it impossible to select files from the SD card.
      Is there a way to disable the error messages so they don't keep popping up?
      My Hardware setup is: Duet2 Wifi 1.04C + Duex5 and PanelDue 5i
      FW: RRF3
        jay_s_uk @Scrabart
        @Scrabart try disabling WiFi.
        M552 S0
        • Scrabartundefined
          Scrabart
          Thanks. That seems to work.
          I guess I was concerned that I would't be able to re-connect unless I had a USB connection, but I see that I can just use M552 S1 at the console on the PanelDue.
          Thanks for helping with what should have been obvious to me. I'm not used to this hardware.
