    Z-Probe offset (RRF3.0)
    • ludisnet
      ludisnet last edited by
      I have a Z-probe (IR probe) ...with offset (see image)
      • Should I fill it in under G31? and can you confirm the sign/direction of the offset according to my image?
        G31 X20 Y-10
      • When i generate the bed.g (with http://www.escher3d.com/pages/wizards/wizardbed.php), do I have to fill in the offset as well ?
      Thanks.
      Ludis
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @ludisnet last edited by
        @ludisnet
        1 - Yes, use G31. It depends where you home to. If you home in the bottom left then X would be a minus value and y would be a positive.
        2 - The firmware sorts the offset out itself so no adjustments to the bed file need to be made
        • ludisnet
          Thanks for reply,
          if my image is a top view, with the hexagonal nozzle in the center of the bed, my z-probe is shifted to the top left, the result would be : X-20 Y10?
          • jay_s_uk
            @ludisnet
            Yes. You could confirm by using the jog buttons the move the nozzle in the -x and +y directions
