    Help with M106 R2
    • TCundefined
      TC
      Hi I am trying to use the R2 parameter of the M106 command. As far as I understand the sequence:
      M106 S0.5
      M106 P0 S0
      M106 R2
      should set my Fan 0 to half speed then stop it immediately and then restore the half speed again when it is needed later. Unfortunately this is not what happens. The fan remains stopped. What am I missing?
      Thanks ahead
        M106 R2 means restore the speed of the print cooling fan to what it was just before the most recent tool change.
        M106 R1 means restore the speed of the print cooling fan before the most recent pause.
        • TCundefined
          TC
          Ah so it is really bound to the tool change... ok thanks for the fast reply 🙂
