    Linear rail axis vibrates a lot with duet 2 wifi (v1.04)
    • johny
      johny last edited by
      I am building a printer with linear rails and duet wifi.
      I am using 2A motors (17HS16-2004S1).
      When configuring i setup the current for 950ma and X16 micro stepping with interpolation and the axis vibrates a lot; if i increase the current the vibration rises when I start to lower the current the vibration is reduced. Only at 500 ma, the vibration gets into a point that is acceptable. should i be using 80% of the motor current like 1600ma? what am i doing wrong?
      Thank you
      • johny
        Just a small note, i am using 12V PSU.
        Thank you
          Does this vibration happen when you command movement around a particular speed? If so, my guess is that you are hitting a resonance at that speed, either mid-band resonance of the motor, or resonance of the frame.
          If it's only only one of the motors causing vibration, that can be caused by a partially-failed stepper driver.
          Another possible cause is trying to move the motors too fast for the supply voltage. As you are using 1.8deg motors, I don't think this is very likely; but you should check whether the supply voltage is adequate for that speed using the motor EMF calculator at https://www.reprapfirmware.org/.
          I suggest you run those motors at between 1.3A and 1.6A.
          • johny
            @dc42 said in Linear rail axis vibrates a lot with duet 2 wifi (v1.04):
            adequate
            Hello, Vibration happen when i move the axis in the dashboard buttons i guess standard speed. I already changed the stepper (plugged on a different) and changed motors as well; i can only reduce the noise when i change 906 to 500ma
            • johny
              johny last edited by johny
              The noise using 1250 ma
              In the end i loose the belts the the noise is reduced
                dc42 administrators @johny last edited by
                @johny said in Linear rail axis vibrates a lot with duet 2 wifi (v1.04):
                Sounds like a resonance then.
                • johny
                  It was a small gap in the linear rails that made the resonance! changed the rails and no noise!
                  Thank you
