    Manually extruding issues with new interface
    Duet Web Control
    1.5k
    • flyschaundefined
      flyscha
      Since upgrading to the new interface, I have not been able to manually retract or extrude filament. I've let both heaters come up to temp as well, but the options still remain grayed out. Am I overlooking something that has changed between the two interfaces? Thank you for any help!!
      droftartsundefined Tron_Livesundefined 2 Replies Last reply Reply Quote 0
      • Ntrackundefined
        Ntrack
        Probably you need to select a tool , usually T0.
          droftarts administrators @flyscha
          @flyscha from the image it looks like the tool is active, I think. So either the minimum temperature for extrusion has been set high with M302 https://duet3d.dozuki.com/Wiki/Gcode#Section_M302_Allow_cold_extrudes , or the tool is not configured correctly. Send M302 on its own to check the state, post response from console. If that doesn’t help, please post your config.g.
          • flyschaundefined
            flyscha
            Thank you for the replies!
            There was no M302 command anywhere in my config, so I used the link @droftarts provided to write that line. I'm still having the same result. Funny thing is, everything worked great in the original interface.
            Here is my config.g:
            ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
            ; generated by RepRapFirmware Configuration Tool v2 on Sun Mar 31 2019 19:33:17 GMT-0700 (Mountain Standard Time)
            M569 P0 S0 ; Drive 0 goes backwards
            M350 X32 Y32 Z32 E16 I0 ; Configure microstepping without interpolation
            M92 X322.00 Y322.00 Z1602.00 E215.00 ; Set steps per mm
            M566 X900.00 Y900.00 Z25.00 E450.00 ; Set maximum instantaneous speed changes (mm/min)was 900,900,12,450
            M203 X12000.00 Y12000.00 Z4000.00 E800.00 ; Set maximum speeds (mm/min)E was 5000
            M201 X1200.00 Y1200.00 Z500.00 E500.00 ; Set accelerations (mm/s^2)was 600,600,250,250
            M906 X1800.00 Y1800.00 Z1400.00 E1700.00 I0 ; Set motor currents (mA) and motor idle factor in percent
            M84 S500 ; Set idle timeout
            M208 X220 Y220 Z240 S0 ; Set axis maxima
            M574 X1 Y1 Z0 S0 ; Set active low and disabled endstops
            M558 P5 I1 R0.35 X0 Y0 Z1 F650 T6500 H2 ; Set Z probe type to effector, the axes for which it is used and the dive height + speeds
            G31 X0 Y0 Z-0.100 P100 ; Set Z probe trigger value, offset and trigger height (more negative is further from the bed).
            M557 X4:210 Y10:210 S66.666666 ; Define mesh grid
            M143 H0 S100 ; Set temperature limit for heater 0 to 100C
            M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
            M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M563 P1 D0 H1 ; Define tool 1
            G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
            G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
            M302 S120 R110 ; Allow extrusion starting from 120°C and retractions already from 110°C
            Thanks again for the help!
              @flyscha What firmware are you running? Your config.g says "firmware version 1.17 to 1.19", though you may have updated it. If you're running old firmware with the latest DWC, that might cause issues. Send M115 and post the response. Which version DWC? If you left the files on the SD card, you can use the old DWC by pointing your browser to "[your-ip-address]/reprap.htm".
              I can't see anything obviously wrong with your tool setup. What happens if you send M302 P1, which should allow cold extrudes?
              • flyschaundefined
                flyscha
                @droftarts Here's that response:
                M115
                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.04 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-11-01b1
                Duet Web Control 2.0.4
                Sending M302 P1 shows green as though it accepts the command, but the extrude & retract buttons are still grayed out.
                  @flyscha Hmm... can you run M98 P”config.g”. This will run the config.g and show any errors, that you don’t see at startup.
                  • flyschaundefined
                    flyscha
                    @droftarts When I run that command, it says:
                    HTTP is enabled on Port XX
                    FTP is disabled
                    TELNET is disabled
                    Again, thanks for your continued help!
                    • Ntrackundefined
                      Ntrack
                      What happens if you send T0 P0 from console?
                      Edit: I can see now you have your tool selected. I cannot see M584 in your config.g
                      • flyschaundefined
                        flyscha
                        @Ntrack T0 P0 code gives me a green box with a check mark to show it accepted the command, but nothing changes.
                        You're right, there is no M584 in my config.
                        • deckingmanundefined
                          deckingman @flyscha
                          @flyscha You haven't defined a Tool 0 in your config.g - only a Tool 1. As you only seem to have 1 tool, then I suggest you define it as Tool 0 (numbering always starts at 0) or send T1 instead of T0 before you attempt to extrude. To be clear, in config.g replace M563 P1 D0 H1 with M563 P0 D0 H1.
                          • flyschaundefined
                            flyscha
                            @deckingman Replacing the P1 with P0 in the config file was the trick! Now the retract option is available immediately when I activate the hot end heater, and when it reaches 160c, the extrude option is now available. Hooray! Again, it's just odd that everything worked with that exact same config in the previous interface.
                            Thank you to everyone for the help! I really appreciate it!
                            deckingmanundefined 1 Reply Last reply Reply Quote 1
                              deckingman @flyscha
                              @flyscha I think in general, slicers will default to using T0 if no tool is selected when slicing. If they don't put a T(n) command in the gcode file then you'd be fine, but if you used slicer which did put a T(n) command in, then the default would be T0. So defining your single tool as T0 in your config.g is the safer option.
                              • flyschaundefined
                                flyscha
                                @deckingman Ok, great. Thank you for the explanation, that makes complete sense!
                                • Tron_Livesundefined
                                  Tron_Lives @flyscha
                                  @flyscha I've checked my config and it looks like I'm still having the same problem despite having the correct lines. Is there anything else I can check? I'm only able to get the retract and extrude to come up if a start a job and then immediately cancel it.
                                    deckingman @Tron_Lives
                                    @tron_lives said in Manually extruding issues with new interface:
                                    You can only extrude and retract if two conditions are met. 1. A tool must be active. 2. The tool must be hot.
                                    From what you say about starting and cancelling a job, it sounds like you still don't have "T0" in your config.g file as I suggested before. So you are relying on there being a "T0" in your sliced gcode file.
