    DWC2 and nginx reverse proxy - cont.
    Duet Web Control
    • Nxt-1undefined
      Nxt-1
      I have decided it is time to pick up my reverse proxy endavours where I left them at the end of these threads 1 and 2.
      The end goal is to have mydomain.com/dwc lead to well... dwc. A number of other locations are also defined in the same reverse proxy, doing various things. On the forum I have seen others using a catch all location block (ie. location / { } ) for this purpose. While this config works for me, is leaves out the /dwc part of what I want.
      In the config below I started to experiment with adding locations for all the missing paths, but this cannot the way to go. Anyone more experienced that can explain to me how I can achieve what I want?
      mydomain.conf
      location /dwc/ {
      	include /etc/nginx/proxy_params;
      	client_max_body_size 0;										# Don't limit upload size and pass it on immediately without buffering
      	proxy_http_version 1.1;										# WebSockets need explicid http 1.1
      	proxy_set_header Upgrade $http_upgrade;						# Make nginx treat this as a WebSocket
      	proxy_set_header Connection "upgrade";						# Make nginx treat this as a WebSocket
      	proxy_pass http://websocket;
          location /css/app.0b5b36ba.css {
          location /js/app.cc04b2b3.js {
      nginx.conf:
      map $http_upgrade $connection_upgrade {
              	default upgrade;
              	'' close;
          	upstream websocket {
              	server 192.168.1.55;
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
      • chrishammundefined
        chrishamm administrators
        I don't think it's a nice solution to redirect static DWC2 resources. You may be better of building DWC2 with publicPath set to /dwc instead of / in your case. This will create a new bundle that loads DWC2-related files from /dwc instead of /.
        Duet software engineer
        Nxt-1undefined 1 Reply Last reply Reply Quote 0
        • Nxt-1undefined
          Nxt-1 @chrishamm
          @chrishamm said in DWC2 and nginx reverse proxy - cont.:
          I agree it is not a nice solution, or even a solution at all. While rebuilding DWC2 custom for me, will most likely work, and I have though about it as well. I am not a fan of having to build firmware myself each time an update comes around. Unless I can convince you the publicPath should be set to /dwc by default 😉 .
