    Paneldue i7: can the display be rotated?
    PanelDue
    • Trackpinundefined
      Trackpin
      Restarting a Workbee build and looking at mounting an i7 panel at 45 degrees in a pre existing 3d printed enclosure. Ideally would like to rotate screen output and leave erase/sounder/reset holes where they are, rather than hack enclosure, or rework/reprint. Can the screen orientation be changed in firmware? Have done this in a Pi3 project but have no experience (yet!) of the finer points of Duet/Reprap. Any help appreciated.
      Trackpin
        Yes I believe the screen can be flipped 180 degrees in the setup page, but it can't do a portrait mode if that's what you're after.
        • Trackpinundefined
          Trackpin
          Thanks for the prompt re[ly, I will look out for the setup option. 180 deg will be fine. I had noted thread regarding 90 deg problems, hence thought best to ask!
          Trackpin
            The option you want in the setup screen is Invert Display. Flips it upside down.
