    Cannot Connect with WebInterface/Usb
    Firmware installation
    928
    • ProjectK
      ProjectK last edited by
      Hey There,
      got a little Problem here:
      I deleted all Files on the Duet via Webinterface because after uploading configs generated by https://configurator.reprapfirmware.org/ it doesnt react anymore. I tried to reupload the original files which i backup'ed via SD card, but it didnt work either.
      Now i cannot connect via WebInterface. connection via Repetier-Host works, but it wont accept any G-Code like M997/M999.
      what should i do?
      Servusla
      Project-K
      Karani
      Creativity knows no borders!
      • T3P3Tony
        Which Duet do you have?
        What does your SD card directory structure look like?
        Duet Hardware Designer
        www.duet3d.com
        • elmoret
          elmoret last edited by
          Could you post a screenshot of your computer's Control Panel, specifically the Ports section?
          • ProjectK
            i have the latest Duet with the ESP8266 wifi Module, i bought it like 2 months ago :3
            i dont know the exact name, but its not the Ethernet one.
            The firmware i was using was also the latest one (1.18 stable)
            Kind regards,
            Project-K
            Karani
            Ps.: it's my first forum thread (ever), which way do you guys recomend to upload pictures?
            • elmoret
              Bossa program port means that the firmware on the main processor has been erased, you need to re-flash it.
              https://duet3d.com/wiki/Updating_main_firmware
              Fallback Procedure 3 is what you're after.
              • ProjectK
                thanks for the reply! i will try it with SAM-BA 2.16 🙂
                Atmel takes forever to send the Download link, but i will see.
                i will give you feedback when it's done!
                Best Regards
                Project-K
                Karani
                • T3P3Tony
                  As an aside, imgur works for images, just right click then "copy image address" (in english at least) then past that link in the image tabs, for example your:
                  becomes
                  www.duet3d.com
                  • ProjectK
                    Nice!
                    Now it works!! thank you guys, you're awesome! 🙂
                    • T3P3Tony
                      Awesome!
                      www.duet3d.com
