Solved Filament sensor status
Is there any way to get the filament sensor status to confirm whether it's working correctly without having to run a print?
I'm only using a simple switch so having a present or not present status report would be more than adequate. -
@jay_s_uk M591 D0 (or whatever drive it's fitted on) should report how it's configured, and if it's a switch, if filament is loaded or not.
@droftarts perfect thank you
